Engine upgrades #386339 01/24/04 07:54 PM
MAXWELL Offline OP
I have a '84 4runner project and would like to get a bit more horsepower out of it. I live in Portland, OR, so I have emissions to deal with though. Major bummer. I haven't decided though what I'm going to do yet. Lately, I've been thinking about going the 22RE route, which from what I'm gathering is better when dealing with emissions in that you can get more horsepower through mods, but won't have to worry about emissions, as much I.E. -> LC Engineering offers a kit that's all emissions legal and gives you an additional ~ 20 hp which, to begin with, the 22RE has a bit more than the 22R, which would be satisfactory for me. BUT, I know nothing about EFI except what little I've been reading about in the last week or so, enough that I'm not sure if I want to hassle with changing heads, and converting everything else, & also making sure all the EFI components, sensors are working correctly (as I would be purchasing a used engine).
My other idea was. . .screw the emissions, build up a carb 22R engine ('87 block/heads) with oversized valves, Weber carb, headers, cam, etc. . .and swap out the engine every 2 years when I have to renew tags <img src="/forums/images/graemlins/smile.gif" alt="" />. I'm thinking a 2" exhaust system, higher-flowing cat, mounted as configured as stock as possible, in case I'd have to put the stock exhaust/cat back on if/when emissions won't pass with my "emission test" engine.
Any suggestions? Bang for the buck? Easiest, most practical solution(s)?
Re: Engine upgrades [Re: MAXWELL] #386340 01/24/04 08:11 PM
DRTDEVL Offline
Give EB a call. He can get you 143 HP out of the 22-RE for under $1000. You're local to him, too... He can answer any questions about his setups.
I personally run his 270* cam, SS OS valves, Steel Rail timing set, and bored 0.040 over. Runs good, lasts long time. Emissions legal, too.
Go with a staged exhaust... Stock manifold and downpipe, high flow cat, 2" to the muffler, and 2 1/4" out the back.
Re: Engine upgrades [Re: DRTDEVL] #386341 01/24/04 08:14 PM
MAXWELL Offline OP
Yeah, this is the guy I was going to go through, too, if I went the "outlaw" carb 22R set-up. Thanks for the input!
Re: Engine upgrades [Re: MAXWELL] #386342 01/24/04 09:37 PM
BennyBoy Offline
My friend did it this way(I'm going to do this too),He removed the head put in EB oversized
ss valves,a TRD stage one cam and a LC ss header.I've driven his truck before and after and
it's a night an day differents.His truck is an 84 22r and the new cam and header are smog legal.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6018 MB (Peak: 0.6586 MB) Data Comp: Off Server Time: 2026-07-16 07:36:27 UTC
