Page 8 of 8 1 2 3 4 5 6 7 8
Re: Longer Struts [Re: maraguez] #387389 09/22/04 05:55 PM
wd8cdh Offline
I started a new thread for the longer Sportage struts so we don't fill this one up with off topic posts.
See thread "Longer Sportage Struts" started 9-22-04
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
Re: electric fan. Has anybody DONE it? [Re: maraguez] #387390 09/22/04 07:01 PM
Nukeiridium Offline
I have the Eibachs with a lift spacer, probably same as what Maraguez has, and I have to say I wouldn't want the lift any higher... At full droop it already seems to put a lot of stress on the suspension and the strut barely fits in there. The CV boot has no room to spare either. Not worth it if you ask me, if you want extreme lift just start workin on a solid axle like Dave did... I mean there's only so much you can expect the stock suspension to do...
An alternative that I would love to see would be a longer A-arm kit with beefier springs and separate shocks instead of the strut setup. This would be so nice, it would provide longer travel, more lift, etc. I heard one was in the works but I guess it never got done <img src="/forums/images/graemlins/frown.gif" alt="" /> Fiberglass fenders might be in order for this smile
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: electric fan. Has anybody DONE it? [Re: Nukeiridium] #387391 09/22/04 07:32 PM
maraguez Offline
I agree, need more lift, go with the straight axle. With the lift I have I worry when I go off road and once I start to stretch in the gullies, the CV's will start to give me trouble. I plan to go with a straight axle as soon as I can. I know a guy in Mexico who installs them so I might go that direction. He installed them on a Tracker, very similar to the Kia and the Tracker went on to win a bunch of competitions.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
Re: electric fan. Has anybody DONE it? [Re: maraguez] #387392 09/22/04 07:55 PM
Nukeiridium Offline
Let me know if you get a price from the guy and if I could go to the same guy (and what part of Mexico this is).
I'm going to San Felipe on the Baja peninsula this weekend <img src="/forums/images/graemlins/coolg.gif" alt="" /> Va a ser bien chido...
Re: electric fan. Has anybody DONE it? [Re: shifter26] #387393 09/23/04 02:13 PM
Dave Scott Offline
shifter, you have the new upper strut mounts, these do exactly the same thing ron is suggesting, only his way is more expensive.
Re: electric fan. Has anybody DONE it? [Re: Dave Scott] #387394 09/23/04 02:51 PM
wd8cdh Offline
Shifter,
My way is better only if:
a. You need new struts.
b. You need more than 1" longer struts.
c. You don't know how much longer you need.
d. You want adjustable rebound stiffness struts.
Ron Schroeder
Long Island NY
Re: electric fan. Has anybody DONE it? [Re: wd8cdh] #387395 09/23/04 09:35 PM
shifter26 Offline
well im good for now .. i wont be doing any mods on the sportage for a good while .. im trying to save up and get some money for downpayment for a house ... so ill be looking for a house next year and thats where all my money will go for awhile .. so the sporty will stay like this till i get settled down .. but its doing great ..
Re: electric fan. I'm going to try. [Re: shifter26] #387396 09/24/04 01:58 PM
wd8cdh Offline
Hi Rey,
Actually I'm good for now too since I have spacers in the front for both lift and to lower the strut. I'm just doing the lengthening experiments for other people to use. After I lengthen them and document the process, I will rebuild them at stock or 1/2 inch longer than stock.
To keep on topic, I just found an electric cooling fan that I was going to put on my Isuzu pickup. I was looking to see if it would fit the Sportage and it looks like a go. I might be able to make brackets next week.
Ron Schroeder
Long Island NY
Re: electric fan. I'm going to try. [Re: wd8cdh] #387397 10/04/04 01:57 AM
LadyFrog Offline
Just finished installing my new electic fan
have to say I absolutely love it!!
Was very easy to install didnt have to remove the radiator
used an adjustable switch thermostat
had a little help from the big guy as far as where to install the switch and yes it has a relay and a fuse
also connects to the AC positive so that it comes on when the AC is on...maybe I'll put in a shut off switch later
but it is deffinately better then the old fan was <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
LadyFrog
I miss my little Kia
Re: electric fan. I'm going to try. [Re: LadyFrog] #387398 10/10/04 02:05 AM
Well hey if Ladyfrog can do it.... <img src="/forums/images/graemlins/lol.gif" alt="" />
Just joking!
I have to do the timing belt this weekend, figured if I'm pulling all the belts I oughta replace em all too. Then I got to figuring if I gotta pull the fan....
So wish me luck, it goes in in the morning come hell or high water, especially high water! <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6430 MB (Peak: 0.7684 MB) Data Comp: Off Server Time: 2026-06-09 10:09:46 UTC
