2.6 Silent Shaft and chain elimination #389187 01/28/04 03:10 PM
kmac Offline OP
This has pobably been dicussed numerous times, but here goes agin. Looking for information regarding the removal of the balnace shafts and chain. I know the left silent shaft can be deleted by using a oil drive chain and sealing the oil feed hole in the bearing journal. And it looks like the rt silent shaft behind the oil pump could be too. Advantages, disadvantages.
Mopar Engines Speed Secrets and racing modifications for Chrysler v-8, 6 and 4 cyl engines. Detailed specs on how to build a race engine from your 4 cyl including 1600cc -2600 from carbs to cams, cyl heads to intakes. Also gives the tube dia and tube length to build yourself a custom header. Part #P5249010
MOBIL STAND MAN with 1989 Dodge D-50 2.6 5spd 4WD sport cab factory original (not for long) 2.6 on the engine stand being built to RUN. www.mobilstands.com
Re: 2.6 Silent Shaft and chain elimination [Re: kmac] #389188 01/28/04 04:57 PM
1987Raider Offline
Buy the balance shaft elemination kit from NAPA. Includes everything you need (chain, special bolt, ring to seal the oil feed hole, gaskets, etc) and complete instructions -- not that this is rocket science! Best I recall the kit is about $40 or so.
I got rid of mine about 20K ago, and haven't had a problem. You may have vibration related problems if your engine is seriously unbalanced (I semi-balanced mine in rebuild) or if you have aluminum brackets, which are reported to be prone to crack from vibration after the shafts are removed.
Terry
1987 Raider 2.6L Auto -- rebuilt, by hand, by me -- Bouncy Seat/LSD/Aisin Hubs -- CB/Whip Antenna --Jensen Stereo -- Fire extinguisher .
Re: 2.6 Silent Shaft and chain elimination [Re: 1987Raider] #389189 01/28/04 05:12 PM
kmac Offline OP
Thanks I will check into it. On a scale of 1-10 what would you number the vibration without the balance shafts. I know it can't be as bad as having just one behind the oil pump.
Re: 2.6 Silent Shaft and chain elimination [Re: kmac] #389190 01/28/04 07:01 PM
1987Raider Offline
I would imagine that lwaving one shaft in would be far worse than taking both out! The I understand that the shafts "balance" each other out, as well as engine vibration. Leaving one in might make the truck undriveable!
I balanced the connecting rods and matched the pistons when I did my rebuild, so it may or may not affect the vibration I feel. On a scale of one to ten, with the engine with both safts installed being a 5 (and the higher you go the worse the vibration) I would put the engine with the elimination kit at about a 5.5 or 6 -- I can barely tell a difference, if at all.
Some others who have eliminated the shafts without balancing have had more vibration, but I guess it depends on how out of balance the engine is to begin with.
The hardest part of installing the kit is removing the timing cover. The shafts pulled from my engine with only a hefty tug with my hand (after removing the bolts, of course).
Terry
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6017 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-06-07 11:35:47 UTC
