limited slip diff question
#390219
01/30/04 01:02 AM
My stepfather's truck has a Dana 60 limited slip rear axle with 3.73 gears. Today, when stuck in the snow(common in central New York), I noticed that only one tire was spinning, meaning that the limited slip diff isn't functioning as it should. Does this mean that the clutch packs in the diff are shot or would the truck not move at all if this were the case? I've never seen what happens when a limited slip wears out... does it act like an open diff?
Thanks for any input.
My '86 4Runner went to the bone-yard November 29, 2004 at 10am after roughly 430,000 miles on the original engine and transmission. :-( Looking for something else to wheel in...
Re: limited slip diff question
[Re: ecowheeler]
#390220
01/30/04 01:55 AM
Thanks for any input. Dead clutch pack? Maybe. Or, it could be as simple as the WRONG GEAR LUBE! There's a gazillion lubes out there, and not all of them have the friction additives for LSDs. Try some different grease. I think that you're looking for the API Spec GL-5. Or, you can buy the friction additive from many parts stores. Try that first. Anyone else know for sure? Zuk? 4Crawler? Anybody?
[Re: ecowheeler]
#390221
01/30/04 01:56 AM
Nothing's wrong with it, it's acting as a LSD should when stuck in the snow and neither wheel has any traction.
Some light action on the brake pedal sometimes helps it send power to both wheels.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 - '84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
[Re: fourwd1]
#390222
01/30/04 02:45 AM
fourwd1: Seemed to me like one wheel had better traction than the other(one side was on packed snow, the other was on smooth ice, ice skating rink style :-P ).
As far as the oil in the differential, The bottle used to fill it says in very plain language that it is for limited slip differentials. In fact, it was purchased at a GM dealership(the axle is for a Chevy 3/4 ton diesel). Though there are no guarantees that the stealership wouldn't lead a customer astray, I'm reasonably certain it is the right stuff.
Thanks for the help, everyone.
[Re: ecowheeler]
#390223
01/30/04 06:01 AM
Sounds like the clutch packs are worn. You might replace them and shim the spring. I haven't taken one of those apart but if it's anything like the Supra LSD's, shimming the spring hels a ton.
Frank.
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos. www.sdori.com
