Bad Intake Manifold Gasket... #390948 01/31/04 05:36 AM
glock Offline OP
Based on my post: "Dreaded "Check Engine" light..." it appears there is a chance that I am looking at a leaky Intake Manifold Gasket...Some technical advice please:
Under the NY Sate Used Vehicle Limited Warranty (60 days) from the dealer, I have til this coming Tuesday to get it in to them for coverage...
If indeed this would be covered...
Covered parts under the Power Train:
A.Engine
block
cylinder head
engine and all internal parts
flywheel(only on cars with automatic transmissions)
fuel pump
manifolds
rotary engine housing
water pump
"If your engine, transmission, drive axle, brakes, radiator, steering, alternator, generator, starter or ignition system (excluding the battery) are defective, the dealer or his agent must reoair or, if he so choses reimburse you for reasonable cost of repair."
Does a defective Intake Manifold Gasket fall under this warranty at 46,000 miles?? Anyone?? <img src="/forums/images/graemlins/confused.gif" alt="" />
2012 Jeep Liberty
2000 Trooper 3.5, LS/Burgandy & Grey(O.B.T.2)...<img src="/forums/images/graemlins/cheers.gif" alt="" />
I WAS down with O.B.T. '88 Trooper II
("Old Blue Trooper!" said my kids!...)
Re: Bad Intake Manifold Gasket... [Re: glock] #390949 01/31/04 06:56 AM
rubo Offline
It should be, but don't forget this is NY we are talking about so who knows what the dealer will BS you with.
Are you gonna join us @ kicking some Kia <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> March 6?
"If i can't crawl over it, i'll fly over it"
rubo
'96 Amigo 4x4, 3.2L V6, 4L30E, D44 rear, SOA, 1" BL, undergoing surgery.
'00 Rodeo LS 4x4, 3.2L V6, OME 919 Springs, front cranked to match,1" BL, 265/70x16 Scorion A/T's.
Re: Bad Intake Manifold Gasket... [Re: glock] #390950 01/31/04 07:00 AM
TLB Offline
I know in reference to my own ride (99 rodeo) it was covered under the powertrain warranty. Also your Trooper should be covered until 5yrs/60,000 miles, according to Isuzu. Good luck in getting this solved <img src="/forums/images/graemlins/kewl.gif" alt="" />
Tim Barlow
Tim Barlow
05' Sequoia SR5
98' 4Runner SR5
Re: Bad Intake Manifold Gasket... [Re: TLB] #390951 01/31/04 07:19 AM
glock Offline OP
Tim Barlow
Hey, Tim...As a 2nd owner, that 5 yr/60k doesnt wash anymore! <img src="/forums/images/graemlins/angry.gif" alt="" />
Rubo- whats the deal-io with Kia come March 6th? <img src="/forums/images/graemlins/notooth.gif" alt="" />
2012 Jeep Liberty
Re: Bad Intake Manifold Gasket... [Re: glock] #390952 02/01/04 06:09 PM
glock Offline OP
OOOOK...A little carberator cleaner sprayed around the intake manifold gasket area brought on the telltale engine response...and flickering check engine light...
Wish me luck with the dealer... <img src="/forums/images/graemlins/shiner.gif" alt="" />
2012 Jeep Liberty
Re: Bad Intake Manifold Gasket... [Re: glock] #390953 02/01/04 08:29 PM
Rodayo Offline
Why not? Is that some funky NY law? When I bought my Rodeo second hand, the warranty came with the car.
1996 Rodeo - 3.2L, 5sp., ARB Bull Bar, Rancho 9000x, Eclipse sound
2004 Rodeo - 3.5L DI, Auto
Re: Bad Intake Manifold Gasket... [Re: Rodayo] #390954 02/01/04 08:53 PM
rubo Offline
IIRC in NY the warranty dosn't come with a car (when you buy it used), unless dealer chooses to give you one.
You can always buy an extended warranty, but they are realy expensive in NY.
rubo
Re: Bad Intake Manifold Gasket... [Re: Rodayo] #390955 02/02/04 06:47 PM
glock Offline OP
I take it back... Per Isuzu, the 5 year/60K Powertrain warranty is applicable...and the intake manifold gasket most certainly is covered...
Dealer initially told me they were booked thru next week, then told me I could indeed drop 2nite- but no promise they would get it done tomorrow!!...I'm working on getting a loaner from them right now... <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
2012 Jeep Liberty
Re: Bad Intake Manifold Gasket... [Re: glock] #390956 02/02/04 10:12 PM
central Offline
Make sure they do BOTH gaskets. Granted only one is likely leaking now. However the other one cannot be that far behind. No sense in waiting for it to go bad later (maybe after the warranty expires?) when Isuzu knows now that they put out a bad original gasket design.
Re: Bad Intake Manifold Gasket... [Re: central] #390957 02/03/04 12:16 AM
glock Offline OP
Good heads up, central...How you think that logic will fly?
2012 Jeep Liberty
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6396 MB (Peak: 0.7649 MB) Data Comp: Off Server Time: 2026-11-19 05:26:54 UTC
