axle deal #392703 02/03/04 11:44 AM
no_hank Offline OP
hi all. I was shopping around for a lathe/mill and came across what looks to be a pretty good deal on some heavy duty axles. here are the axles. and a description. the price is around $950 for the pair.
One of our 28-1471 GM four wheel drive front axle assemblies with one of our 28-1472 GM four wheel drive rear axle assemblies. Even better savings on a matched pair of new replacement axles for your four wheel drive vehicle! Shpg. 911 lb
GM 4WD FRONT AXLE ASSEMBLY WITH BRAKES
New GM four wheel drive front axle assembly originally made for military application. Brakes are complete with rotors and calipers. For use with six-lug tires. 3.08:1 gear ratio. These axle assemblies fit 82-91 4x4 Blazers, 81-91 4x4 CHEVY and GMC trucks, and 81-91 4x4 CHEVY and GMC Suburban.
GM REAR AXLE ASSEMBLY WITH BRAKES
New GM rear axle assembly originally made for military application. Includes ten bolt posi-traction rear, hubs, drums, brakes and emergency brake cables. For use with six-lug wheels. 3.08:1 gear ratio. These axle assemblies fit 82-91 4x4 Blazers, 81-91 4x4 CHEVY and GMC trucks, and 81-91 4x4 CHEVY and GMC Suburban.
97 TJ Sahara 4.0, K&N FIPK, 2.5" rancho, 31x10.5 BFG, black rims, tuffy stuff, hi-lift, AA SYE+tom woods CV rear, tera adj. upper rears, centerforce dual-friction, MSD coil/8.5mm, borla cat-back, warn steering skid, slotted rotors+high perf pads.
Re: axle deal [Re: no_hank] #392704 02/04/04 04:47 AM
That's a lot of cash for the same axles you can get at your local junkyard for less than half the price. Don't buy intot the "made for military" crap (definitely not "heavy duty"). They are your standard GM 10 bolts with crappy gears in them.
The front differential is on the wrong side for your TJ anyhow.
Re: axle deal #392705 02/04/04 11:46 AM
no_hank Offline OP
I wasnt looking at them for myself. I was just shopping around for a small lathe/mill/cnc setup when I saw them, and thought somebody around here might be interested. I figured under $1k for two complete axles with brakes and stuff was pretty decent. oh well, back to the grindstone.
Re: axle deal [Re: no_hank] #392706 02/04/04 01:37 PM
Hey...thanks for sharing though man! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: axle deal >> figuring your total cost!!! #392707 02/05/04 01:11 AM
I am saving towards a set of full size truck axles for my 88 YJ currently running 3.73's with 33's. I'll be doing a spring over with probably 2' leafs and 4.88's or 5.13's on 36" or 37 "tires.
Here's some things to consider as additional costs from your initial cost to purchase the axles. Unless your buying the set with the gear ratio, lockers, etc.. that you plan on running.
Ring and Pinion (2 sets) $400
Installation Kits (2)
Detroit Locker (Rear) $350-$500
Posi/LS/Selectable $300-$500
Bearing and Seals
Labor $550-$650
What I'm saying is that most who upgrade their axles will incur the latter costs.
Re: axle deal [Re: no_hank] #392708 02/05/04 05:18 AM
Not really. I get complete axles at the junkyard for $60 each and I do get heavy duty axles, not little 10 bolts. You might say that I don't know what kind of condition my junkyard axles are in, but who's guaranteeing the condition of these $1K axles? The gears aren't really what I would want for an "upgrade" anyhow.
Re: axle deal >> figuring your total cost!!! #392709 02/05/04 07:49 PM
no_hank Offline OP
like I said, I am not interested in purchasing these axles, or any other axles at the moment. I was shopping for a lathe/mill.
Re: axle deal #392710 02/05/04 07:53 PM
no_hank Offline OP
condition is listed as "new", but like you say, there are no guarantees in life. I didnt no do any research on the axles, nor did I really even pay attention to the specs, since, like I said, I am not interested in them for myself. I saw a pair of new 4x4 axles for ~$1k, and though "hey the jeep people might be interested". doesnt make a rats ass to me if anybody wants them or not, just passing it along.
Re: axle deal [Re: no_hank] #392711 02/06/04 02:15 AM
BigJim Offline
<img src="/forums/images/graemlins/drunk.gif" alt="" /> Howdy No Hanky
Personaly I think it was very considerate of you. There was a time a few years back when I needed those very axels and would have went for the deal.
Big Jim
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6197 MB (Peak: 0.7232 MB) Data Comp: Off Server Time: 2026-06-13 10:58:14 UTC
