Which Mobile 1formula should try first?? #393544 02/05/04 01:23 AM
ducktrooper Offline OP
I did several searches...but here's my question. '99 Trooper just hit 100K and valve ticking becoming more noticeable. I will try Mobile 1, but not sure if I should start out 0W30, 5W30, or 10W30...or if it even matters.
Reason for my question is the hot, humid climate here and several posts I read about TSB and starting off with 0W30.
Thoughts anyone?
'99 Trooper, ARBs, 4.77s, ARB bullbar, Warn M8000 w/Amsteel, OME 912s w/2.5" spacers, Rancho 9000xs, K&N/Magnaflow, 33" Kumho MT's, Aisins, boulder bars, Indy 4X brake lines, diff drop, Flexalite
Re: Which Mobile 1formula should try first?? [Re: ducktrooper] #393545 02/05/04 02:55 AM
holger Offline
If you would take a look into their specs, you would find that
all those Mobil1 oils are actually virtually the same
product, with minor differences, and all of them are
mutually compatible. Do not worry and use whatever you want.
Re: Which Mobile 1formula should try first?? [Re: holger] #393546 02/05/04 03:13 AM
I agree. They are all a 30wt at operating temp, so go with whatever is easiest to get for you. I know in my area any 0w-XX is near impossible to get over the counter. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Joel
Re: Which Mobile 1formula should try first?? #393547 02/05/04 03:38 AM
Joel
AutoZone here on Long Island stocks 0w/30. You would think in a colder place like where you are would be an easier find.
As for oil weight, I'm using 5w/30 mobil 1 as that's what the dealer puts in. I've been using it since the first oil change and now have about 33,000 on the engine with no issues. At first I was losing no oil what so ever but the last 6k miles, I've been losing about 1/2 quart every 3k miles. I'm not too worried as I have remote start now so I think the extended warm up times might be eating the oil more. Can't complain for a three year old vehicle.
Cheers,
Con
Re: Which Mobile 1formula should try first?? #393548 02/05/04 08:33 PM
jsanford Offline
i've used mostly 10w30 becaused it seemed to cover the most conditions around here, according to the manual. i'm currently running 5w30 (winter time) and i believe i'm noticing an increase in oil consumption. coincidence or just paying closer attention than in the past, i don't know.
anywho, 10w30 is my vote for no good reason. <img src="/forums/images/graemlins/notooth.gif" alt="" />
joel s.
'01 trooper (the misses') and 265/75/16/C dueler AT
'95 f150 4x4, leveling coils and 32 inch maxxiss buckshots
Re: Which Mobile 1formula should try first?? [Re: jsanford] #393549 02/05/04 09:27 PM
Rodeo Clown Offline
Well, most of what I have read around here has recommended 0 or 5 W30 becuase it (for whatever reason) helps with the valve knock. I didn't pay attention this time when I changed my oil and ended up with 10W30 and the knock is back for me. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> So personal experience says 0 or 5 W30 is the way to go.
1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
Re: Which Mobile 1formula should try first?? [Re: ducktrooper] #393550 02/05/04 09:54 PM
When I had the valve tick I used 5w30, but that was a blend and it still went away. Now I am on 10w30 full synthetic and no knocks or sounds, (thats when the tranny was in the truck and the clutch not pulled out.) <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6120 MB (Peak: 0.7074 MB) Data Comp: Off Server Time: 2026-06-20 20:25:50 UTC
