P235 or LT235 Tires? #393588 02/05/04 03:41 AM
Banchi105 Offline OP
I am going to get some BFG Land Terrains tomorrow
and wanted to know if I need get the P235 or the LT235?
I do 95% highway driving so I dont want an unnecessarily rough ride, but I also dont want a really thin tire that will easily puncture when I do venture off-road.
Thanks In Advance!
Re: P235 or LT235 Tires? [Re: Banchi105] #393589 02/05/04 03:55 AM
neither. 31x10.5 smile
ok, ok, in the size you said, get the LT's. it's a much more durable tire by rating and by definition.
if your butt can tell the difference in the smoothness of the ride, I shall heartily roll my eyes in your general direction <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: P235 or LT235 Tires? #393590 02/05/04 04:31 AM
Thanks for the quick reply!
I would I'm just scared about trimming and dont want tires to be rubbing stuff. I also dont want to do a crappy trimming job and you be able to see it. <img src="/forums/images/graemlins/baby.gif" alt="" /> <img src="/forums/images/graemlins/baby.gif" alt="" /> <img src="/forums/images/graemlins/baby.gif" alt="" />
I wish the 2nd Gen Rodeo wheel wells were bigger...
Re: P235 or LT235 Tires? [Re: Banchi105] #393591 02/05/04 07:41 AM
holger Offline
The solution is to get LT235 load rate C (not D or E).
It will provide good ride (much better that D or E) and it
will be much stronger than P235.
LT tires are much more durable and they provide much better
cornering becouse they have stiffer sidewalls than P tires.
I'd never go back to P tires.
LT tires are more expensive initially but much cheaper in
a long run: P tires requive continious repair and
replacement, according to my experience. I had to fix or
replace a P-tire almost every month, which was no fun and
fairly expensive. But since I switched to LT tires,
I've had no single problem so far
(I have second set now) - no flats, not sidewall
cuts, no sidewall bulbs.
Oleg
Rodeo S 2002 4WD
Dunlops RVXT LT265/70-16
Re: P235 or LT235 Tires? [Re: holger] #393592 02/05/04 03:27 PM
Bigpoppax2 Offline
I had a set of 255/70/16's on my second gen before I had any lift. With no rubbing at all. Just a thought. You should be able to get at least a 245/75/16 with no rubbing. You would be hard pressed to find too many off road tires in a 255.
Re: P235 or LT235 Tires? [Re: Bigpoppax2] #393593 02/05/04 03:32 PM
I agree with the "c" rated option. I spent most (nearly 100%) of the time on-road and did not want a "hard" tire. After some searching, I found a "c" rated tire I was happy ($$$) with. Beware, your LT tire options do decrease once you limit yourself to a class other than D or E.
Tim-
Re: P235 or LT235 Tires? #393594 02/06/04 01:10 AM
Thanks alot for the help.
The land terrains I am looking at are Load Range C.
Anyone had any experience with this tire before?
I know BFG manufactures it exclusively for Wal-Mart, but I am not sure of how nice of a tire it is?
Re: P235 or LT235 Tires? [Re: Banchi105] #393595 02/06/04 01:26 AM
4WDJOE Offline
31s should run nicely on your truck. when i got mine it had 31s on it and i had no problems at all. no lift then either.
97 Rodeo
Re: P235 or LT235 Tires? [Re: 4WDJOE] #393596 02/06/04 06:19 PM
Its just that the wheel wells on 2nd Gens are much smaller.
Thanks anyway though.
Re: P235 or LT235 Tires? [Re: Banchi105] #393597 02/06/04 07:28 PM
holger Offline
I am not sure that this is the case. I run 31s without
any rubbing (265/70-16).
Oleg
Rodeo 2002
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6385 MB (Peak: 0.7629 MB) Data Comp: Off Server Time: 2026-06-10 01:43:16 UTC
