Re: Pulling rear third [Re: jcssurf] #393667 02/06/04 12:10 AM
J-me4runner Offline
If you need help getting them bled in Ch-ville, email or pm me I dont look here much.
Re: Pulling rear third [Re: J-me4runner] #393668 02/06/04 01:22 AM
jcssurf Offline OP
Thanks, I appreciate it
90 pickup, 22RE, stiff-ass Ranchos, 2.25 catback, 4:1 header, conical intake, 15x7 ICW alloys, 32x11.50 Dunlop Mud Rovers, 4.56s w/v6 rear
-Farm truck until school is done...then plans
2000 Honda CRV EX 5 speed
-Driver
Re: Pulling rear third [Re: jcssurf] #393669 02/06/04 04:29 AM
cam01 Offline
I have never bled rear brakes after a 3rd replacement. I always clamp the rubber line and do a quick gravity bleed after everything is put back together, works for me.
88 V6 4Runner, 3.4 swap, SAS, front E locker, rear EZ locker, dual cases 2.28/4.7, 63" Chev rears, rears up front etc.
Re: Pulling rear third [Re: cam01] #393670 02/06/04 05:11 AM
SHAD Offline
Unless they are rusted or super brittle (which I don't think would happen in only 15 years
Well mines a 93 and I have had to splice brake lines because they rusted through already and my runner is only 11 years old.
Hell the whole truck could rust out completely up here in less than 10 because of the salt they use in the winter.
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: Pulling rear third [Re: Red_Chili] #393671 02/06/04 05:15 AM
kewlynx Offline
If you don't want to have a big brake fluid mess take a pair of vise grips and clamp it on the rubber hose that goes to the rear brakes this will stop the dripping brake fluid from coming out that way you will have less of a mess to clean up.
I would regard this as dangerous. Bruises the brake hoses.
I went ahead awhile back and bought a vacuum line crimping plier that's a lot better than vise grips on the hoses. NAPA.
**ubi apis- ibi salus**
Re: Pulling rear third [Re: Red_Chili] #393672 02/06/04 05:18 AM
OOP'S Offline
Yep!!!! And do not do it to S.S. braided lines either!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Pulling rear third [Re: cam01] #393673 02/06/04 04:36 PM
jcssurf Offline OP
What do you mean by gravity bleed?
-Driver
Re: Pulling rear third [Re: jcssurf] #393674 02/06/04 04:39 PM
Red_Chili Offline
Toyota Section Staffer
Dribble. Using gravity. Kinda like my old dog. Slow but often effective, the weight of the fluid from the master pushes the fluid down by the wheel cylinders out. Sometimes doesn't quite do the job, often does.
-Bill
Re: Pulling rear third [Re: OOP'S] #393675 02/07/04 12:24 AM
ErikB Offline
Toyota Moderator
...you do not want the axles to lay on the seals
They won't lay on the seals. They'll rest on the metal part just inside the seals. <img src="/forums/images/graemlins/wink.gif" alt="" />
http://home.4x4wire.com/erik
Re: Pulling rear third [Re: SHAD] #393676 02/08/04 04:13 AM
V
Voyager Offline
Yea, I forget that there are harsher rust climates than southern california desert. <img src="/forums/images/graemlins/smile.gif" alt="" /> We don't get much road salt rust around here. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.018s Queries: 16 (0.014s) Memory: 0.6383 MB (Peak: 0.7628 MB) Data Comp: Off Server Time: 2026-11-19 23:54:10 UTC
