E-brake light on durring acceleration #396773 02/10/04 03:06 AM
RichK Offline OP
Anybody know how to fix this?
My Emergency Brake light turns on when I am accelerating in first and second gear. It is worse when it is cold out.
Thanks,
Rich
1993 4X4 Toyota Pickup XtraCab
22re (ATK Remanufactured)
Re: E-brake light on durring acceleration [Re: RichK] #396774 02/10/04 03:09 AM
little_joe Offline
Former Admin
Top off your brake fluid reservoir.
And, welcome! <img src="/forums/images/graemlins/cheers.gif" alt="" />
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: E-brake light on durring acceleration [Re: little_joe] #396775 02/10/04 03:24 AM
RichK Offline OP
Brake fluid level is normal...
Thanks,
Rich
Re: E-brake light on durring acceleration [Re: RichK] #396776 02/10/04 04:27 AM
kewlynx Offline
I know it sounds funny, but check and make sure your alternator belt isn't slipping. If the alternator has charging trouble, it flags both the brake and charge lights.
If the thing looks glazed, I'd swap 'er out.
**ubi apis- ibi salus**
Re: E-brake light on durring acceleration [Re: RichK] #396777 02/10/04 04:44 AM
Buster Offline
Thanks,
Rich
Fill it to the MAX level and see if the prob goes away.
Re: E-brake light on durring acceleration [Re: Buster] #396778 02/10/04 04:50 AM
Robinhood150 Offline
Yup, all the way to the top and maybe even a hair over.
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: E-brake light on durring acceleration [Re: Robinhood150] #396779 02/10/04 06:33 AM
Stan_Marshall Offline
my brake light comes on once in awhile while driving just because my parking brake system is a bit f'ed up (one bellcrank is frozen and the cables seem a bit stretched), so it doesn't have enough tension to hold the brake lever all the way in.
so, if i shift too hard or hit a bump too hard, the brake lever sometimes pulls itself out a bit and causes the light to come on. i just push it back in (or hit another bump), and the light goes off.
not exactly the same symptoms you have, but easy to check.
stan
1994 4x4 22RE W56 truck
Re: E-brake light on durring acceleration [Re: Stan_Marshall] #396780 02/10/04 07:04 AM
yeah check the alternator, mine e-brake light would come on too when accelerating and stuff and the charge light, and i replaced the alternator and it doesnt do it anymore.
Re: E-brake light on durring acceleration [Re: RichK] #396781 02/10/04 10:28 AM
Do you have snow/ice built up under the truck? I've had occasionally in the past where the ebrake light would come on under the conditions you stated and it was just cause the cable was jamming up in the snow/ice and the handle would slide back causing the light to come on.
Re: E-brake light on durring acceleration #396782 02/10/04 03:48 PM
Red_Chili Offline
Toyota Section Staffer
As said,
a) top off fluid,
b) replace cap
You did a), now do b). I worked on my rear axle bearings the other night and lost some brake fluid (not much), leading to exactly the symptoms you describe. In my case a) worked.
-Bill
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6361 MB (Peak: 0.7587 MB) Data Comp: Off Server Time: 2026-06-22 01:12:37 UTC
