Just spent a whole lotta $$$ #398849 02/13/04 01:52 AM
johnny_boy02 Offline OP
Im rebuilding my front-end soon, I just ordered a bunch of parts from Allpro and Marlin. I just want to know if I got everything I will need.
Profields
Cro-Mo inner axles
knuckle rebuild kit
2 new wheel bearings kits
2 inner axle seals(as extras in case I mess one up putting it in)
2land cruiser front brake rotors
Knuckle Pull Scale
54mm Hub Socket
I also got a couple knuckle studs, Stud Nuts, Stud Split Washers, and Stud Cone Washers just in case I loss/break any of the ones I have.
Please let me know if im forgeting anything thanks....John <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Just spent a whole lotta $$$ [Re: johnny_boy02] #398850 02/13/04 02:23 AM
Esquire812 Offline
Geez...no point in getting all them parts unless you are stocked up on the #1 most overlooked item to have on hand when playing the wrenches.
Other than that...aint got a clue man...sorry.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Just spent a whole lotta $$$ [Re: Esquire812] #398851 02/13/04 02:30 AM
LoL, its cool, Your the engine expert. I'll need your help soon enough. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Just spent a whole lotta $$$ [Re: johnny_boy02] #398852 02/13/04 02:46 AM
OOP'S Offline
Profields
Cro-Mo inner axles
knuckle rebuild kit
Knuckle Pull Scale
54mm Hub Socket
A couple of pounds of grease and I find these real handy:
MAGNETIC PARTS TRAYS
ò Holds small parts
ò Carry with you
ò Plastic protectors prevent scratches
ò SX7000M-6" Round Tray
ò SX7010M-9-1/2" x 5-1/2" Rectangular Tray
ò SX7040M- 11-3/4" x 11-3/4" x 1-1/4"
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Just spent a whole lotta $$$ [Re: OOP'S] #398853 02/13/04 04:48 AM
Thanks OOP'S, I was hoping you would chime in. What kind of grease should I use? Best place to get it?
Re: Just spent a whole lotta $$$ [Re: johnny_boy02] #398854 02/13/04 05:04 AM
IFS calipers.
Re: Just spent a whole lotta $$$ [Re: johnny_boy02] #398855 02/13/04 06:17 AM
OOP'S Offline
I use a Extreme Pressure, Moly-Graph, GP Grease made by Sta-Lube seems to work. I do not have Birfields I have an eliminator kit hhat was built by RedLine, D-44 Warn alloy axles with Spicer 670X u-joints but I used the same grease when I did have Birfields!!!! Don't forget to put some grease on the lip of the axle seal before you put the axles in!!!!
David Fritzsche
Roseville, CA
Re: Just spent a whole lotta $$$ [Re: johnny_boy02] #398856 02/13/04 06:44 PM
Paul Elbisser Offline
once you go to IFS calipers your wheels may hit them. Wheel spacers may be needed. I am only running 1/4" on mine with minimal grinding on the caliper.
Paul Elbisser #3233
pastTLCAEastern Rep.
Pres Rice on the Rocks
www.riceontherocks.org
Re: Just spent a whole lotta $$$ [Re: Paul Elbisser] #398857 02/15/04 01:57 AM
after doing this whole thing about 6 months ago i can tell you best advice, go generously on the moly grease. Really pack that crap in there. Oh and some other things of note would be a case of that dollar store orange oven cleaner so you can clean up the outside of the knuckle etc. Bolts go back on much better when they are clean!!!
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6257 MB (Peak: 0.7303 MB) Data Comp: Off Server Time: 2026-07-15 06:51:24 UTC
