rear springs on front without cross over steering #399080 02/13/04 10:41 AM
BJWEST Offline OP
dont have an extra $400! is it posible? how?
Re: rear springs on front without cross over steering [Re: BJWEST] #399081 02/13/04 12:33 PM
rob_dup1 Offline
i doubt it, the rears up front flex alot. i think something will hit alot.
don't know for sure though
Re: rear springs on front without cross over steering [Re: rob_dup1] #399082 02/13/04 03:24 PM
4Crawler Offline
The biggest issue is that you'll likely need more than 4 leaves in the front spring pack and too thick a pack will cause the drag link and steering J-arm to hit the u-bolts on the driver's side. You can use special flattened u-bolts (like OME sells) or a flipped ball on the J-arm (and an adjustable drag link) to get clearance for a thicker spring pack. Reason for the thicker pack is that rear springs are fairly soft, for example I run 6 rear load leaves plus an anti-wrap leaf on my front springs.
Re: rear springs on front without cross over steering [Re: 4Crawler] #399083 02/13/04 08:37 PM
fourwd1 Offline
Another issue is that rears up front move the axle forward ~2", so you'd need adjustable drag link and torque rod, or x-over.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: rear springs on front without cross over steering [Re: BJWEST] #399084 02/14/04 08:55 AM
Snowtoy Offline
I would wait and save up the $$ for the x-over steering. When we did my buddies truck last spring the steering was scary enough on the street that my buddy opted for the x-over.
Re: rear springs on front without cross over steering [Re: BJWEST] #399085 02/14/04 02:40 PM
Save up the extra money and do it right.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6087 MB (Peak: 0.6783 MB) Data Comp: Off Server Time: 2026-06-20 22:18:06 UTC
