Manual hubs increase gas mileage ? #399803 02/15/04 12:19 AM
BrownBox Offline OP
Just curious if anyone has ever checked mileage before and after switching to manual hubs? I'm considering the switch.
Doug
95 Toyota 4Runner V6 auto
94 Chevy Z71
06 Arctic Cat 700 EFI
http://community.webshots.com/user/brownbox
Re: Manual hubs increase gas mileage ? [Re: BrownBox] #399804 02/15/04 12:34 AM
My father noticed a difference of about 3mpg when he switched to manual hubs on his Explorer - for whatever that's worth.
Re: Manual hubs increase gas mileage ? [Re: BrownBox] #399805 02/15/04 04:07 AM
little_joe Offline
Former Admin
At best, you'll get a nominal increase - *maybe* 1mpg if you've religiously checked mileage. The truck will launch a little better due to lessened mechanical drag when the hubs are unlocked.
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Manual hubs increase gas mileage ? [Re: BrownBox] #399806 02/15/04 09:12 AM
Jeff the marmot Offline
I don't have an actual number for you, but I can tell you I was disappointed that I really didn't notice a difference. I keep records, but only occasionally calculate the exact mpg. Years ago I could tell about 2 mpg difference on a '79 Ford Bronco. But with my 4Runner it's probably more like 0.5 mpg improvement if that. Quite often I'm getting better gas mileage (by 1 or 2 mpg) when I have the manual hubs locked only because that means it has snowed during that tank-full so I'm using 4wd and accelerating slower and driving slower then.
It's a bigger advantage that manual hubs save the life of the CV boots and also allow some creative possibilities of getting off the trail if there's severe off-roading damage to anything in the front.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Manual hubs increase gas mileage ? [Re: BrownBox] #399807 02/15/04 03:08 PM
No increase in MPG for me--just a lighter feel to the front end, and the knowledge that things that dont need to spin are not spinning.
Just get Aisin hubs if you are going to do it--
aisin hubs
Re: Manual hubs increase gas mileage ? #399808 02/15/04 08:23 PM
BrownBox Offline OP
Thanks for all the info. Sounds like manual hubs aren't worth the effort just for the gas mileage. Maybe when I decide to use it more offroad i'll switch to aisins.
Doug
94 Chevy Z71
Re: Manual hubs increase gas mileage ? [Re: BrownBox] #399809 02/15/04 08:32 PM
Even if you don't use it offroad, you should still switch. Switching to manual hubs greatly reduces wear-and-tear on your front driveline.
On another note, I didn't really notice any mpg increase either.
Re: Manual hubs increase gas mileage ? [Re: BrownBox] #399810 02/16/04 03:49 AM
bkg Offline
Do the switch... for $60, it'll be worth it. You may or may not notice a significant increase in mileage, but you should do it anyway. My 4Runner DOES get better mileage when the hubs are unlocked, but I also do not have ADD anymore (well... my 4Runner doesn't... <img src="/forums/images/graemlins/drunk.gif" alt="" />). Do it - it's worth it if only for peace of mind.
Brian K. Gallus
Re: Manual hubs increase gas mileage ? [Re: BrownBox] #399811 02/17/04 07:01 AM
anthony1 Offline
It's more like switch so you can disconnect the hub when you're not off-road.....which sounds like you do that more.
Besides, you can lube the whole 4wd parts by driving in 4hi with the hub unlock too.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Manual hubs increase gas mileage ? [Re: BrownBox] #399812 02/20/04 07:05 PM
va_roadrunner Offline
I would do the switch too if the ORS manual hub kit for my 2001 4Runner wasn't $1039. Add install time and it gets highter. That's alot of overtime to save up to cover the costs.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6366 MB (Peak: 0.7559 MB) Data Comp: Off Server Time: 2026-11-18 11:55:48 UTC
