Wrong Idler Arm??? With Pics #400416 02/16/04 05:14 AM
I went to rebuild my idler arm to get rid of the usual annoyances, but forgetting one of the bushings at my house on campus made that hole thing stop. This may be good because the idler arm on my truck looks a lot different than the one in the write-up.
First pic is the write-up from Joe's truck:
Now my truck:
It sure looks like the pair of bushings that I have are going to have a hard time getting in there. Were there different arms for different years and would I be better served in switching to the "other" one for strength?
I have never seen anyone else mention such a thing. Interesting, to me at least.
Re: Wrong Idler Arm??? With Pics #400417 02/16/04 05:33 AM
Wyatt Offline
That doesn't look like any factory Toyota arm. NAPA has a ultra-cheap one for $59 (I don't know what it looks like though), and a premium Beck-Arnley "555" unit for $120, very similar to the top pic.
The top pic looks like a Moog unit though, which runs about $95 at Pepboys. My guess is your's is not really serviceable.
I'm your Huckleberry
96 4Runner LTD,S/C,headers,2.5 w/ 285's
89 4Runner SR5 V6,locked,33's
Wyatt's Toys
Offroad Pics
Re: Wrong Idler Arm??? With Pics [Re: Wyatt] #400418 02/16/04 05:50 AM
fpkelly Offline
I don't think I've ever seen one like yours on a Toyota. My 4Runner had one like the top pic and all of the Toy's I've seen have one just like it. Browsed Advance Autoparts online and got this pic- [Linked Image]
Re: Wrong Idler Arm??? With Pics #400419 02/16/04 06:12 AM
Leo Offline
I've never seen an idler arm like yours either. Mine was different and it looked like Little Joe's. I would replace it with the one like Little Joe's, that idler arm does not look strong enough...just my 2 cents. <img src="/forums/images/graemlins/cheers.gif" alt="" />
2000 - Tundra, V8 2WD Access Cab
Re: Wrong Idler Arm??? With Pics [Re: Leo] #400420 02/16/04 07:15 AM
Allen Offline
I agree. Definitely not a stock idler arm on your truck. At least not one I've ever seen has looked like that.
Allen Dickenson TLCA #6318 http://www.geocities.com/Baja/Trails/8895/
1995 4Runner UnLimited - Fort Knox - SAS'd,Marlin'd, Locked, Warn'd & Dented.
1977 FJ-40 - Stock
Re: Wrong Idler Arm??? With Pics #400421 02/16/04 07:46 AM
I would get a stock one at a junkyard and use the bushings you got to rebuild it. Much cheaper than buying a new one.
Re: Wrong Idler Arm??? With Pics #400422 02/16/04 10:15 AM
anthony1 Offline
This is what mine looks like before SAS.
I can't get the arm off the tie rod so....um....shipping would not be a good idea.
http://home.earthlink.net/~audiorat1/images/ideler%20arm%20gutset.jpg
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Wrong Idler Arm??? With Pics #400423 02/16/04 02:39 PM
Jason_dup1 Offline
When I got mine last year, I started a post about this very same thing. old post The one you have is a TRW replacement arm, lifetime replacement warranty from advance auto. It is the one in the black and white pic above, it just doesn't look like the drawing. It's the same one I bought. It's been fine on my truck, except for the fact that the previous one I had on there (previous owners, and a TRW also) went bad in a way that is not normal for the much stronger toyota arm. It went bad (started wiggling, showed excessive play) in the area in your picture where the nut is. The bottom arm would wiggle in a way that was obviously not good, so I replaced it w/ another TRW. I figured since it only took me 20 minutes to change it out, I don't care if I have to do it even once a year for that price, hell, 50$ for 2 or 3 idler arms isn't bad!
Jason
1992 4runner, all stock, just got it. only 24k miles!!!!!!!!
1992 Toy Pickup V-6 Reg Cab
33 BFT AT/ko, 3 lift
230k miles
Re: Wrong Idler Arm??? With Pics [Re: Jason_dup1] #400424 02/16/04 11:37 PM
Thanks for confirming my obvious conclusion.
I have worked on the truck before and have definitely looked at the idler before, but it never dawned on me that it would be different. I just always looked and thought, "Mmmm, idler."
If I had the luxury of living in Cali or elsewhere of size and warm climate, the yards might have Toys. Around here, any place within 2 hours is empty of idlers let alone Toys.
Solution is hit up local parts place and ask for something with a written lifetime warranty, then grease it up and bolt it in?
Re: Wrong Idler Arm??? With Pics [Re: anthony1] #400425 02/17/04 12:17 AM
Leo Offline
You need a tie rod puller...I have one if you need it.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6364 MB (Peak: 0.7563 MB) Data Comp: Off Server Time: 2026-05-29 15:27:47 UTC
