parking brake adjustment #400581 02/16/04 04:05 PM
mjletts Offline OP
over the past year my parking brake seems to have "stretched out" and pulls a lot further out then it used to. I'm not even sure its working as well as it used to. Just wondering if it's tough to adjust this. The dealer <img src="/forums/images/graemlins/bird.gif" alt="" /> said it wasnÆt covered under warranty, it was normal wear and tear. Thanks.
Matt
'03 Tacoma Double Cab, 2.5" Pro Comp Spacer up front, AAL in the Rear.
Re: parking brake adjustment [Re: mjletts] #400582 02/16/04 06:03 PM
john_luttrell Offline
Pretty easy to adjust, look under the truck about mid ways back and you will see the cable where it splits off into 2 cables. There is an adjuster at that point. With the park brake lightly set, turn the adjuster nut to tighten it up.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: parking brake adjustment [Re: mjletts] #400583 02/16/04 06:05 PM
Yes it's normal wear and tear, no sweat you can adjust it in under 10 minutes. On my 99' v6 4x4 the adjustment is under the truck, about where the drivers door is. Just look under the truck and follow the cables. You loosen a jam nut, then spin the adjuster nut until you have the desired slack in the cable, then tighten up the jam nut. You might want an adjustable wrench or pair of vice grips to hold the cable still while you spin the adjuster nut. It's a no brainer once you see how it works. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: parking brake adjustment #400584 02/16/04 06:31 PM
mjletts Offline OP
thanks fellas. I didn't think it would be a big deal. Just didn't know where to start looking. Now, i just need some warm weather!!!
Re: parking brake adjustment [Re: mjletts] #400585 02/16/04 07:17 PM
Just a thought, before you adjust your parking brake, check your rear brake drums, make sure you tighen up your shoes back there first. This adjustment will help tighten your parking brake also and maybe you will not need to mess with your parking brake cable at all.
Re: parking brake adjustment #400586 02/16/04 08:10 PM
mjletts Offline OP
how tough is it to tighten the rear brakes? and how do i know if they're lose? I've never really dealt with brakes too much. I always wanted to learn how to change my own brakes because i've heard it's not that bad. I guess now is a good time to get familiar with the them.
Re: parking brake adjustment [Re: mjletts] #400587 02/16/04 08:30 PM
I have two articles for you.
Toyota Rear Brake Job
4Runner Brake Replacement
scroll half way down the page for rear brakes.
Re: parking brake adjustment #400588 02/17/04 12:46 PM
mjletts Offline OP
hey thanks for the articles. Doesn't sound like too big a job. Once the weather gets better, i'll give it a try. Thanks again! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: parking brake adjustment [Re: mjletts] #400589 02/18/04 01:12 AM
E
ed_herman Offline
2-17-04 As stated, you should adjust the rears. I believe using the parking brake does that. So use it frequently.
Re: parking brake adjustment [Re: ed_herman] #400590 02/18/04 12:26 PM
mjletts Offline OP
Ed, i don't think i understand what you're saying. If you use your parking break it adjusts the rear brakes?? I use my parking brake very frequently.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6301 MB (Peak: 0.7521 MB) Data Comp: Off Server Time: 2026-11-01 22:31:25 UTC
