Rear axle seal question #34825 05/31/02 01:09 AM
Nato99 Offline OP
I'm in the process of doing my rear brakes and when I pulled off the drum on the passanger side the brake workings in between the shoes is covered in axle grease, a lot of it!! The wheel cylinders don't appear to be leaking and I'm not loosing brake fluid so I'm fairly sure it axle grease. So...how do you go about replacing the axle seals and does it require a press?
It's an 86 4runner, 22RE non turbo
Thanks
'86 4runner
ARB bull bar, Warn 8000, daily driver
Re: Rear axle seal question #34826 05/31/02 02:14 AM
You don't need a press for the seal but you do for the bearing <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" /> take the axle/drum to a machine shop to get the bearing pressed out and a new out pressed in plus you'll need a bearing race( ?)or some sort of solid bushing ,I can't remember which <img border="0" alt="[Drunk]" title="" src="graemlins/drunk.gif" />
Re: Rear axle seal question #34827 05/31/02 04:52 PM
ErikB Offline
Toyota Moderator
Generally this is a symptom of a bad wheel bearing. In order for the oil to get that far, it has to go through the inner seal (in the axle housing), the bearing, and then the outer seal.
Theoretically you need a press to get the bearing off and to get at the outer seal, but there are other ways- like the "slam it on the concrete method" which has always worked well for me. <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
http://home.4x4wire.com/erik
Re: Rear axle seal question #34828 06/01/02 03:01 AM
Replace the bearing too. The diff lube washes out the grease.
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5952 MB (Peak: 0.6546 MB) Data Comp: Off Server Time: 2026-06-07 13:03:49 UTC
