Page 1 of 3 1 2 3
Strange Idiot Lights #403194 02/20/04 12:49 AM
A
AZPetrak Offline OP
OK, I have something strange going on.
On my Rodeo my battery light and brake lights are intermittently and randomly flashing/flickering, but together(does that make sense?).
EDIT<It is RPM, at about 2K the lights (both voltage & brake) start to flicker, at about 2.6K they are on constant.>EDIT
The lights (batt & brake) flash/flicker but it seams to only happen when I am accelerating, and maybe in a certain RPM range.
EDIT<I checked the voltage at battery, 12.2V engine off, 14.2V engine at idle>EDIT
Has anyone experienced anything like this?
Does this even make sense to anyone?
HELP
2007 4x4 Tacoma Dbl Cab with TDR and rear locker - stock for now
2001 Wrangler Sport - sold
1998 Rodeo S 4x4 - traded in
Re: Strange Idiot Lights [Re: AZPetrak] #403195 02/20/04 12:55 AM
Canucklehead Offline
It sounds like your alternator is trying to tell you "Replace me!!"
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: Strange Idiot Lights [Re: Canucklehead] #403196 02/20/04 01:44 AM
Banchi105 Offline
Its your alternator. In a short amount of time your radio will start cutting out followed by your dash (tach & speedo) and headlights. Exact same thing happened to me a while back
Rodeo Problems
i had it rebuilt for $35 - good luck
Re: Strange Idiot Lights [Re: AZPetrak] #403197 02/20/04 02:18 AM
since everyone else is saying alternator...I'm going to say voltage regulator...but I'm not an electrical engineer so don't take my word for it <img src="/forums/images/graemlins/shame.gif" alt="" />
Re: Strange Idiot Lights #403198 02/20/04 02:34 AM
W
Wayne Offline
Sorry, it was me. I was passing thru the area and your Isuzu was letting you know. (Think about it...)
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: Strange Idiot Lights [Re: Wayne] #403199 02/20/04 11:45 AM
Thats the dying alternator idiot lights.
Re: Strange Idiot Lights #403200 02/20/04 04:01 PM
O
OffRodEO Offline
for sure it is the alternator, or wires connecting to it. When my harmonic balancer went out i had to take the belt off because the pulleys were not lining up. So i had to keep charging my battery for about a week.
The idiot lights would be on, but when i hit the freeway, upon accelerating the lights would blink. check your voltage, it should be low or going down.
how long has it been doing this?? your battery cannot last very long
kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
Re: Strange Idiot Lights [Re: OffRodEO] #403201 02/20/04 06:34 PM
litnin Offline
It may not be the alternator... but most likely is.
My Stylus does the exact same thing and I have replaced the alternator, with a factory unit.
Mine seems to happen mostly when the outside fans kick on. as soon as the shut off, the lights go out... I've also noticed the do it at high RPM hard accelerations.
I think I had a bad ground or something, somewhere.
It has not affected the running or drivability of the car, so I haven't looked any further... maybe one day I will.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Strange Idiot Lights [Re: litnin] #403202 02/20/04 11:55 PM
A
AZPetrak Offline OP
I thought it was the alt, but something I forget to say is that I checked the voltage at the battery, 12.2V with engine off, and 14.2V with engine on at idle.
I also noticed that it is RPM sensitive. At about 2K the lights (both voltage & brake) will start to flicker, and around 2.6K they are on constant. If it was the alt, why does the brake light come on? I was thinking maybe the voltage reg is going out, and over driving (V too high) at the higher RPMs.
Is this possible??? I will have to get my wife to rev the engine while I am looking at the voltage.
Re: Strange Idiot Lights [Re: AZPetrak] #403203 02/21/04 02:41 AM
Jim_Paget Offline
Someone posted here within the last few months with a problem of his alternator working at idle but not at higher RPMs. Sorry I can't remember much more about it than that.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6357 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-07-14 01:48:50 UTC
