Largest tire on IFS Isuzu #405264 02/23/04 07:52 AM
rodeo_chris Offline OP
I know there are always posts asking "Whats the largest tire I can run on my Isuzu?", well here's one that is going against all reason.
I will soon be stepping up in tire size as well. Got a great deal on some surplus Hummer tires. 7-36's at 40% for $100. I'll be picking them up next Saturday.
They won't go on right away. I have to find some 16.5" 6 lug wheels first. -> Wanted
I also need to fix my squishy brakes first, but spring break is coming up real soon. <img src="/forums/images/graemlins/smile.gif" alt="" />
-chris
94 Rodeo, 35's, 5.38's, locked F&R, Rocker bar on one side, other side in garage
96 Tacoma, DD, pre-dented
Re: Largest tire on IFS Isuzu [Re: rodeo_chris] #405265 02/23/04 07:58 AM
kobyhud Offline
I think the rumor has it that 35s on IFS is just begging for breaking the CVs. Looking at the setup on my rig, even dropping the front axle housing a bit, I would say this sounds about reasonable. A few have made posts on this board about grenading their CVS after going to 35s.
I know there are a few guys running the 35s on the IFS, but most were ready to grenade the CVs and were just looking for a chance to put a solid axle under there anyway.
IF you are going to wheel it hard, just be prepared if you do break something.
95 Rodeo LS, Auto, SAS, , 60 front, 14 bolt rear. 5.13 r&p, Hydro-Assist, teras..
http://www.pieceofhud.com/gallery
Re: Largest tire on IFS Isuzu [Re: rodeo_chris] #405266 02/23/04 02:12 PM
RobG Offline
hummm.. thought H1's rode on 37s and H2's on 35s. I didn't know there was a Hummer that came with 36s <img src="/forums/images/graemlins/confused.gif" alt="" />
16.5's eh? are you looking for something with bead locks? As you know hopefully know, the bed retenion on the 16.5 isn't very good for airing down.
should definitely be interesting to see how things hold up. I'd expect you'll do ok, as you're right foot isn't quiet as heavys as Rubo's <img src="/forums/images/graemlins/shocked.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> But nonetheless, you'll need to watch out for those cv's and steering components.
-Rob
-Rob
Re: Largest tire on IFS Isuzu [Re: RobG] #405267 02/23/04 06:21 PM
E
Eric Upchurch Offline
have you dropped the front diff? or are you planning on it? not sure if you remember seeing daniels truck at uwharrie but his drop diff worked out pretty good, and should keep those cvs alive maybe a little longer. good luck, post some pics when you get them.
New rig: 89 trooper RS toyota axles with 5.29s, 35x15.5x15 swamper SXs
my Pics: http://community.webshots.com/album/124372714fTyMKI
Wrire up:http://personal.ecu.edu/emu0416/
Re: Largest tire on IFS Isuzu [Re: Eric Upchurch] #405268 02/24/04 01:38 AM
Rodeo Guy Offline
So are these tires similiar to the michelin military tires, they last forever and can be regrooved a couple times? Aren't they REALLY heavy?
You plannin on droppin the diff or smurfin the cvs? How far down the road is that SAS?
Get some wheels and get em mounted up. We want pics!
Mike
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: Largest tire on IFS Isuzu [Re: Rodeo Guy] #405269 02/24/04 03:59 AM
I am planning to space the front diff down some. A SAS is in my future, so maybe these will help it along. Like RobG said, I think that my right foot being so light will help keep me from breaking stuff.
I've been told that these tires wear like iron and ride like crap. Here's a few pictures of the tires. I promise I'll get some pictures of them either mounted on the truck or I'll stick them under there just to check my clearance and snap a pic.
-chris
Re: Largest tire on IFS Isuzu [Re: RobG] #405270 02/24/04 05:46 AM
matthew Offline
the military HUMV's all had 36's...... bias ply
you wil not find a 16.5 in 6 lug....as that was a 1 ton wheel size.......8 lug will be what you find.
you could get a custom wheel....but that is the deal breaker on the "cheap tires" <img src="/forums/images/graemlins/frown.gif" alt="" />
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: Largest tire on IFS Isuzu [Re: matthew] #405271 02/24/04 06:40 AM
I've found that early 90's chevy trucks had an option of 6 lug 16.5's, but they are extremely rare and I know about the hub clearance problems with those. I'm currently in contact with a guy in Raleigh with a used set of aftermarket wheels for sale for $200. I'm waiting to see if I think they will physically fit before throwing more money into this route. I'm not too worried about being able to resale if I decide that they won't fit without too much trouble.
-chris
Re: Largest tire on IFS Isuzu [Re: rodeo_chris] #405272 02/24/04 03:08 PM
i've seen 8 to 6 lug conversions, but by getting a set you have now made those "cheap tires" expensive. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Largest tire on IFS Isuzu [Re: rodeo_chris] #405273 02/24/04 03:23 PM
you need to talk to James (coronakid on tdub) about wheels that will fit. He could probably find you a set that would work.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.008s) Memory: 0.6402 MB (Peak: 0.7662 MB) Data Comp: Off Server Time: 2026-11-16 01:19:07 UTC
