Ground wire kits?
#405357
02/23/04 02:05 PM
Is there any real benefit to these?
Re: Ground wire kits?
[Re: CDUFF7]
#405358
02/23/04 02:13 PM
Not really just maybe stronger starting and better spark. I made my own kit I used 8 gauge and 4 gauge wire. Some people have used 0 and 2 gauge wire on thier vehicle.
[Re: SHAD]
#405359
02/23/04 02:20 PM
I see so many claims about horsepower gains and fuel econmy. Seems kind of hard to believe.
[Re: CDUFF7]
#405360
02/23/04 02:53 PM
I guess some people like myself try to mimick the grounding web effect which supposedly makes a stronger spark which is supposed to boost hp..
[Re: CDUFF7]
#405361
02/23/04 02:53 PM
I ran a 2 gauge cable to my frame instead or running 15' of it to my rear winch. I also ran a 8 gauge wire to the fuel injection. I seems like truck runs a little better now. Not necessarily any more power.
#405362
02/23/04 03:05 PM
If it helps me run a little smoother, I may have to install some wire, I will just buy the stuff seperately - not going to buy the kit.
[Re: CDUFF7]
#405363
02/23/04 03:52 PM
Just curious, got a link to these kits? <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: CDUFF7]
#405364
02/23/04 04:42 PM
I've never heard of a ground wire kit.
I wouldn't suggest using the frame for a winch ground. Better to run a ground wire direct to the winch.
Toyota grounding wires are marginal but adequate. Just cleaning up existing ground connections will probably gain you as much as installing new grounds. If you want to replace the wires anyway then go ahead and use bigger ones.
[Re: SHAD]
#405366
02/24/04 03:51 AM
Thank you for all the helpful information.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6328 MB (Peak: 0.7393 MB) Data Comp: Off Server Time: 2026-11-16 08:32:04 UTCValid HTML 5 and Valid CSS
