Low radiator fluid, but why?? #406162 02/24/04 04:07 PM
Johnyrrr Offline OP
So here in Michigan its a cold winter and i start noticing that my 02 blows only luke warm air when at a light or not moving at all. as soon as i get going though the thing blows hot air again like no big deal. So im trying to think of things to look for when i get home as to what the cause might be. Temp guage is fine, 40k miles. So when i stop no loose belts nothing but real low antifreeze in the radiator, so i add about 3/4 of a gallon this morning and all is well, heat again when idleing and so on.
But my question is how did my coolant get low in the first place, i really dont check it alot, but its a toyota and thats why i drive it. I do all the maintenece meticulusly myself and can only thing maybe when i had the tranny flushed at 33k miles at the dealership, maybe they did something. Man do i hope there arent any head gasket issues here, i havent noticed any coolant puddles, though i will start looking more. So do any of you guys think there is something else here going on???? i appreciate all insite. <img src="/forums/images/graemlins/confused.gif" alt="" />
02 4x4 Sport
OME goodies and Brigestone 285's
Flowmaster 50 series(too loud), Alpine in-dash, with a suppertrapp on the tail-pipe to shut the thing up.
Re: Low radiator fluid, but why?? [Re: Johnyrrr] #406163 02/24/04 04:25 PM
I can't believe you would have a head gasket problem but an easy way to check is by looking at the inside of your oil filler cap. There would be a build up of gel on the cap.
Re: Low radiator fluid, but why?? #406164 02/24/04 09:04 PM
fourwd1 Offline
There's only 2 ways to loose engine fluids. Either you're leaking them or burning them. Start looking for coolant on the engine, around the water pump, rad hoses (could be a pin hole spraying, loose clamp...), etc. in addition to puddles. If you'er not leaking you got a bad head gasket, or worse.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Low radiator fluid, but why?? #406165 02/25/04 02:00 AM
code33 Offline
That is not always the case. Depends on where the HG blows. Had a 22r with a blown HG and there was no "milkshake" of oil and coolant. The exhaust was putting pressure into the cooling system.
Re: Low radiator fluid, but why?? [Re: code33] #406166 02/25/04 04:12 AM
fourwd1 Offline
That's quite right. I had an 81 Corona with a 22R with a bad HG, nothing in the oil.
Re: Low radiator fluid, but why?? [Re: fourwd1] #406167 02/25/04 03:45 PM
When coolant loss is internal it will show up inside the engine somehow, either on the dip stick or filler cap or probably both. It does not burn off without leaving behind some evidence.
Re: Low radiator fluid, but why?? #406168 02/27/04 01:28 PM
Johnyrrr Offline OP
thanks everyone for your help. nothing has come up yet all is fine, no leaks found yet, no gelling.?????????????? <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
02 4x4 Sport
Re: Low radiator fluid, but why?? [Re: Johnyrrr] #406169 02/28/04 03:20 AM
code33 Offline
Just keep track of the rate it goes down since nothing is showing.
Re: Low radiator fluid, but why?? [Re: Johnyrrr] #406170 02/28/04 11:12 AM
BruceTS Offline
How long ago did you check your fluid level?
Your water pump may have a very slight seepage problem, but if the level isn't going down that quick, it'll be fine. Look for any signs of fluid leaking from any of the hoses, I had one on the drivers side near the oil filter that was leaking, but was very difficult to spot.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6254 MB (Peak: 0.7243 MB) Data Comp: Off Server Time: 2026-06-09 18:20:17 UTC
