I need the part #'s for the speedo gear #406467 02/25/04 02:56 AM
90amigo Offline OP
Yes I did a search but I need the part number and how many teeth are on the speedo trans gear.I found a shop that will test my speedo error for free.
I saw that post not long ago. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
Re: I need the part #'s for the speedo gear [Re: 90amigo] #406468 02/25/04 03:05 AM
Jim_Paget Offline
Here are a few part numbers passed on to me by a good friend.
8944733080 16 Teeth
8970120851 17 Teeth
8944733040 18 Teeth
8944733031 19 Teeth
8944733021 20 Teeth
The best thing you can do is pull your old one and make calculations from there.
Michael
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: I need the part #'s for the speedo gear [Re: Jim_Paget] #406469 02/25/04 02:06 PM
90amigo Offline OP
Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: I need the part #'s for the speedo gear [Re: 90amigo] #406470 02/25/04 08:29 PM
Bigpoppax2 Offline
Not to hi-jack the post but are these gears good for manual and autos? What years are we talking here? I've got an 88 5-Speed that needs some correction. And I'll have a 98 auto as soon as a change tires.
Re: I need the part #'s for the speedo gear [Re: Bigpoppax2] #406471 02/25/04 10:10 PM
Also, are these the same part numbers for the Troopers?
Re: I need the part #'s for the speedo gear #406472 02/25/04 10:58 PM
JLEMOND Offline
THOSE PT NO,S FOR THE SPEEDO GEARS ARE FOR THE 88-91 TROOPER 5SPD 89-91 V6 AUTO, AS THE TRANSFER CASE IS THE SAME DRIVE SETUP, ALL RODEOS WITH THE 5SPD 4WD AND THE AUTO 4WD SAME SETUP AS THE TROOPER , NOT THE 2WD, 92-97 TROOPERS AND RODEOS ALL WITH 4WD EXCEPT THE TROOPERS WITH TOD, GEARS ARE DIFFERENT ,HOPE THIS HELPS SOME OF YOU OUT JERRY
Re: I need the part #'s for the speedo gear [Re: JLEMOND] #406473 02/26/04 12:45 AM
still unclear. would these part numbers work for a 99 Trooper (automatic).
Re: I need the part #'s for the speedo gear #406474 02/26/04 10:51 PM
JLEMOND Offline
YES THEY WILL WORK , TRANS FER CASE IS SAME DESIGN
Re: I need the part #'s for the speedo gear [Re: Jim_Paget] #406475 02/27/04 03:47 AM
90amigo Offline OP
My gear said 6x18.Next week I will take it to the shop.
[quote]
8944733080 16 Teeth
8970120851 17 Teeth
8944733040 18 Teeth
8944733031 19 Teeth
8944733021 20 Teeth
Michael/quote]
Re: I need the part #'s for the speedo gear [Re: 90amigo] #406476 02/27/04 03:41 PM
RodeoXS Offline
Are those Isuzu part no's or aftermarket??
George <img src="/forums/images/graemlins/nana.gif" alt="" />
92 Rodeo XS 4x4
HomePage
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6330 MB (Peak: 0.7549 MB) Data Comp: Off Server Time: 2026-06-09 10:11:11 UTC
