Hi-Lift Maintenance (Grease it??) #406816 02/25/04 07:31 PM
va_roadrunner Offline OP
Can anyone recommend a grease for the Hi-Lift to prevent rusting when stored on my rack? I've dried it off after my last offroad trip, but couldn't think of what to get. Thanks.
Re: Hi-Lift Maintenance (Grease it??) [Re: va_roadrunner] #406817 02/25/04 07:36 PM
4Crawler Offline
I use a ski binding cover zipped over the working part of mine. Keeps the bulk of the wet and dirt off it and then just apply some light spray oil periodically as needed.
Re: Hi-Lift Maintenance (Grease it??) [Re: 4Crawler] #406818 02/25/04 08:00 PM
Red_Chili Offline
Toyota Section Staffer
Mine is in front of my hood and stays surprisingly clean. I use a shot of WD40 before using it.
-Bill
Re: Hi-Lift Maintenance (Grease it??) [Re: va_roadrunner] #406819 02/25/04 08:22 PM
everything you ever wanted to know about Hi Lift...
http://www.hi-lift.com/
Tony in Healdsburg
Re: Hi-Lift Maintenance (Grease it??) #406820 02/26/04 02:45 AM
I'd go with the suggestion above, some WD40 once in awhile and it should keep faithful for years to come.
Re: Hi-Lift Maintenance (Grease it??) [Re: 4Crawler] #406821 02/26/04 08:11 AM
Seldom_Seen Offline
I found that most petrol based products seemed to attract dirt. I give mine a spray of a wax/teflon concoction made for mountain bike chains. I give it a shot every oil change and no caked on dirt or rust so far.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6096 MB (Peak: 0.6744 MB) Data Comp: Off Server Time: 2026-06-09 21:50:07 UTC
