IAC question from earlier post
#407406
02/26/04 05:32 PM
Several guys were discussing the need to clean the IAC to help with the idle speed. Ever since I have had my truck (95 T100 4x2 V6 MT) the truck has run at 2000rpm at startup. It only lasts for 10 to 20 seconds and then drops to around 1500 to 1750rpm. This lasts until the truck begins to warm up and then gradually drops to 750 rpm where the truck usually idles. I have never had problems starting the truck. I have made the idle change by messing with a something near the throttle body, but I really didn't know what I was doing so I adjusted it back to where it was. Is this normal? Does this sound like a bad IAC? I looked in the Haynes manual last night and there is a procedure to check the IAC but I thought I would ask before I go through the exercise. Any help would be appreciated.
Ryan 95 T100 2WD ExtCab All Stock
Re: IAC question from earlier post
[Re: rmg]
#407407
02/26/04 05:56 PM
That sounds like perfectly normal operation. I suspect you were adjusting the dashpot - little screw on a hinged piece attached to a 1.5 - 2" black cylinder - basically keeps the throttle from closing completely to allow excess exhaust gas to recirculate just after startup, and doesn't do much after you reach normal rpm which is between 650 & 750.
~Adam  96 T100: D44, lockers and stuff
[Re: adam]
#407408
02/27/04 06:20 PM
Thanks Adam. I realize the idle speed should be around 650 to 750rpm. My main concern is the high rpm at startup. I have always been amazed that at cold startup the truck would rev at 2000rpm for any amount of time. I didn't know if the high idle was wrong or just something the T100 does.
[Re: rmg]
#407409
02/27/04 06:43 PM
My main concern is the high rpm at startup. Nah. Kicks up like that for a couple minutes. You should see it start to come off that max of 2k kinda slowly after about a minute (less in warmer weather).
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6008 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-05-30 02:26:17 UTCValid HTML 5 and Valid CSS
