winch installation #407703 02/27/04 12:57 AM
Gellekanao Offline OP
Hope you guys can help.
How would you install a winch on a 96' Montero without a bull bar??
<img src="/forums/images/graemlins/confused.gif" alt="" />
thanks,
Stephen
Exploring the outback is my game!
2005 Mitsu Gen3 Limited
OME Custom Suspension
Custom made safari roof rack
Garmin GPS
32X12.50X16 BFG Mud Terrain
1997 Mitsu Gen2 LS
Safari Roof rack
Garmin GPS
33x11.50x15 BFG MUds
Re: winch installation [Re: Gellekanao] #407704 02/27/04 04:06 PM
L
Lee N Offline
Don't have any direct answers other than you'll have to design it yourself. There's someone here from Norway with the username of Jeepir who has a winch installed below the bumper. Looks like a clean install. PM him and see if you can find out any details. Here's a pic I found -
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: winch installation [Re: Gellekanao] #407705 02/27/04 07:10 PM
DavidG Offline
Gellekanao,
If you hear back from Jeepir could you post the information, I would also be interested in what options exist. I would like to change bumpers and potentially have the option of installing a winch (when the $ is available smile
It looks like TJM Australia may have a solution for a winch mount, but I didn't see a Airbag-compatible, winch-ready listing. I just got off the phone with TJM Products in Tennesse to check on it. He said they do not have any bumpers available for pre-2000 Monteros.
Let us know what you find out,
David
1997 Montero SR
<a href="www.georgiaoverland.com" target="_blank">www.georgiaoverland.com</a>
Re: winch installation [Re: DavidG] #407706 02/27/04 09:19 PM
DavidG Offline
G, I also checked with the ARB folks in Washington. They don't have a listing either. Any of you guys out there running winch bumpers/mounts on a GenII please post...
1997 Montero SR
Re: winch installation [Re: Gellekanao] #407707 02/27/04 09:27 PM
On a gen I there's enough room between the frame rails for a Mile Marker mounted to a plate. They you can simply cut a slot/hole in the middle of the bumper for the cable to feed through and attach a fairlead.
Regarding bumpers, I know Don on this forum makes some sweet aftermarket low profile bumpers for Gen I's. I'm not sure what's exactly involved w/ the airbag mods required but maybe he can do something.
Re: winch installation [Re: off-roader] #407708 02/27/04 10:01 PM
DavidG Offline
Called Warn, nothing there either. Thanks for the info Offroader.
DavidG
1997 Montero SR
Re: winch installation [Re: DavidG] #407709 02/27/04 10:26 PM
David,
Feel free to make those calls but from my experience, unless your talking to an overseas company, you won't find too many companies with anything for a Mitsu.
That being said, there are a few bull bar manufacturers but Mitsu's done some wierd things with their frames in the US versus overseas (where all mitsu bull bars come from unless custom fab'd in N. America).
Thus far I know ECB (east coast bullbar), ARB, & TJM make bull bars in Australia.
Ray
Re: winch installation [Re: off-roader] #407710 02/27/04 11:35 PM
DavidG Offline
The guy I spoke to at the TJM importer mentioned the difference in frame widths. But I believe the brackets can be modified to work (right Angelo?). Looks like I'll have to send some emails out, don't think I'll be calling Australia too many times.
1997 Montero SR
Re: winch installation [Re: off-roader] #407711 02/27/04 11:40 PM
If you do decide to fabricate your own mount, be absolutely certain that it does not protrude forward of the frame mounts...this includes the bracket supporting the bumper.
Problem is, a winch mount placed anywhere near the impact absorbing section of your bumper mounts will (not "can", WILL) affect the deployment threshold of your airbags...if you mount it forward of the "crush cans", they will not absorb collision energy if you hit something...the shock will be stronger to your frame, and your airbags will deploy sooner (at a slower vehicle speed) than designed...the airbags could also deploy in an off-road obstacle impact (that could really ruin your day)!
Winches are for vehicles without airbags...and I DEFINITELY wouldn't waste my time and money to install one just 'cause it "looks cool"...install one ONLY if you have determined you really, really need it...they require yearly maintenance, cleaning, re-torquing of fasteners, cleaning of electrical terminals, proper spooling of cable/rope, PLUS proper training in use. A winch is like a 'loaded gun'...absolutely deadly in the wrong hands.
Alternatively, Warn sells a "pull pack"...basically, a winch mounted to a trailer drawbar...plug it in your receiver, hook cables up to your battery, and away you go!
Rob in Hell
Re: winch installation #407712 02/28/04 01:14 AM
Lloyd Swartz Offline
I dont believe any aftermarket bumper is available anymore. As far as stock, youll need some amount of hardware. Heck, even on a gen I you need a mount plate. The only option I found, and it worked well, involved taking a Ramsey winch mount for a Ford, slicing the stock bumper into 3 sections, welding the winch mount in place,(after some modification) the patching the stock bumper back together around the mount/ bull bar. Looks clean, and you only loose the roller fairleads distance of approach angle, no more. Sounds like alot of work, and it is, but it works better then you might think. If you want more details I can try and help you.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6404 MB (Peak: 0.7667 MB) Data Comp: Off Server Time: 2026-11-17 11:17:22 UTC
