22RE stalling #35381 06/08/02 07:03 PM
G
Genshie Offline OP
I just completed the timing chain replacement on this motor and went to start it yesterday. The motor turns over immediately and runs excellent for about 5 seconds and then stalls out. I can restart it again but after another 5 seconds it stalls. I just replaced the timing chain cover, head gasket and resealed the oilpan. I think it might either be a lack of compression or vacuum issue or maybe a fuel problem? I am not quite sure.
What things should I inspect to help solve this issue?
Thanks!
Kurt G.
Dented 85 4Runner courtesy of Wrecking Ball.
Re: 22RE stalling #35382 06/08/02 10:23 PM
Did you check for intake and exhaust leaks ?
Re: 22RE stalling #35383 06/08/02 10:53 PM
jx94148 Offline
Cap and rotor time? Other ignition issues? Just stating the semi obvious. Clogged fuel filter?
<small>[ 08 June 2002, 08:04 PM: Message edited by: jx94148 ]</small>
'87 4Runner. '83 Honda XL250R. No mods on either.
Re: 22RE stalling #35384 06/09/02 12:56 AM
Genshie,
Not sure if this will help but, the other day my truck backfired on startup, and would only do the same thing yours is doing(start up,die after a few seconds,start up again), I looked around and found out that it had blown the hose from the intake to the breather box (not sure of the right name) off of the intake side. I put it back on and tightened the clamp and it fired right up and never gave me another problem...hope this helps, Dave
Re: 22RE stalling #35385 06/09/02 01:24 AM
toyrunner Offline
Also check the three wires that run from the ignitor across the valve cover for breaks. They have a tendancy to get brittle and crack. I had the same symptoms and got grey hair trying to figure out what went wrong. Found that one wire was broken <img border="0" title="" alt="[Embarrassed]" src="images/icons/blush.gif" />
Danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: 22RE stalling #35386 06/09/02 01:43 AM
G
Genshie Offline OP
Well I did a search on this issue and reading an old post reminded me of something. I forgot to plug in the connector to the AFM when I reinstalled it. That would explain the motor shutting down. I knew it was something simple! <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> Thanks for everyone's suggestions.
Kurt G.
PHP: 7.4.33 Page Time: 0.011s Queries: 14 (0.008s) Memory: 0.6070 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-11-15 19:38:22 UTC
