Attn: XM radio or radio installers
#408107
02/27/04 05:31 PM
My connection diagram says I need to attach one wire to "a terminal always supplied with power regardless of ignition switch position." Can anyone help me out here with a suggestion of where I should attach this wire? Thank you.
2001 SR5 4Runner 4x4
Re: Attn: XM radio or radio installers
[Re: Dbryan22]
#408108
02/27/04 06:42 PM
What are you installing????
[Re: Dbryan22]
#408109
02/27/04 07:38 PM
Battery? Fuse box? if you run it to the fuse box get a test light or meter and find a hot wire when the key isnt on, but try not to use the headlights or something important so you dont overload (although it shouldnt be a problem) but you never know. Then enjoy the XM, it beats the hell outa local radio <img src="/forums/images/graemlins/kewl.gif" alt="" />
#408110
02/27/04 07:40 PM
you could just run it to your head units constant 12 right?
#408111
02/27/04 07:53 PM
Not on my Taco its not. Not even the cig. lighter will work without the key turned,unlike all my prev. trucks.
#408112
02/27/04 08:21 PM
you could just run it to your head units constant 12 right? when you install an aftermarket stereo it has a constant 12 volt to it. as with a stock unit, when you remove the battery you lose your presets etc and sometimes have to enter a code. thats the 12 volts i'm talking about. <img src="/forums/images/graemlins/coolg.gif" alt="" />
#408113
02/27/04 10:17 PM
I was thinking of the constant power supply to the aftermarket radio. The reason is so you don't lose presets when you turn off the vehicle. Thanks everyone.
[Re: Dbryan22]
#408114
02/28/04 01:15 AM
one of the 12 volts to the radio is switched so get the right one
#408115
02/29/04 02:37 PM
J Roll Me Over
It should be a yellow wire to the radio...
BTW: Tis is what actually powers the radio... The "memory" wire. The "power" wire is nothing but a switch, like for a relay.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6179 MB (Peak: 0.6988 MB) Data Comp: Off Server Time: 2026-06-09 23:34:40 UTCValid HTML 5 and Valid CSS
