I could have sworn there was a 2.6L head upgrade post? #410257 03/02/04 06:50 AM
carnuck Offline OP
Can't seem to find it now. Anyways, I finally got a Redline adapter kit and Weber carb for my son's Montero but was wondering if I could just undo the Jet valve lash screws and run it, or if there was a plug I could screw in w/o removing the head?
Build your truck the head men say, but it must be built in such a way...
Re: I could have sworn there was a 2.6L head upgrade post? [Re: carnuck] #410258 03/02/04 03:46 PM
Angel Carlo Offline
There's a jet valve removal kit that plugs the hole where the jet valves reside. I believe TEP sells the kit.
1987 Dodge Raider rebuilt Quest block bored .040 over put together, and installed by Shelby. 5spd, '87 stock turbo, Intercooled, 2.5" exhaust. MPI with hard pipes, FIP Pro-4, MSextra MS1
Re: I could have sworn there was a 2.6L head upgrade post? [Re: carnuck] #410259 03/02/04 03:49 PM
Maybe Clearwater has them also? I'm pretty sure they offer a rebuilt head with the eliminators.
BTW, TEP is Top End Performance in case you hadn't heard of them.
Re: I could have sworn there was a 2.6L head upgrade post? [Re: MontyMcV] #410260 03/02/04 05:38 PM
DanWheeler Offline
Clearwater probably has a set. I sent my head back with the jet valve eliminators! <img src="/forums/images/graemlins/angry.gif" alt="" />
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: I could have sworn there was a 2.6L head upgrade post? [Re: DanWheeler] #410261 03/02/04 09:58 PM
Most any machine shop can order them for you - a common part for the 2.6.
Re: I could have sworn there was a 2.6L head upgrade post? [Re: fasteddy] #410262 03/06/04 10:54 AM
carnuck Offline OP
thanks guys. I forgot to mark this thread as a fav and didn't get any notice ! DOH!
Re: I could have sworn there was a 2.6L head upgrade post? [Re: carnuck] #410263 03/06/04 11:53 PM
KrzyDav Offline
I'm more of a Gen 1 3.0 man , but when living back in Kentucky we had to pass strick smog in the bigger cities.
I passed on buying a couple really goodlooking 4 bangers cause the carb's plastic body part would crack (,with the bad weather big fluctuating changes of midwestern x southern fronts thru tornado alley).
They wouldn't pass smog without a lot of rebuilds.
And the heads had a BAD reputation and the blocks on those counterbalance problems.(also check out www.jasperengines .com.( in Indiana) they re-engineer Known weak spots in engines and have a REAL good reputation,,, and they just opened a couple warehouses in the west.
The Heads ??? with all that oversizing the "Holes" , Ive heard they crack alot between "holes".
John Baker still has some Beefed up Heads on his list that don't crack.
Yous guys might want to check these out.
His place is now called TRUCK and TRACTOR and he's in Wicn. or Minn.
Better hurry , I get the felling he might be getting out of Monteros so better get his good stuff while you can.
Dave
dave h.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6204 MB (Peak: 0.6942 MB) Data Comp: Off Server Time: 2026-06-07 06:00:25 UTC
