Sqeaking Add-A-Leaves #411583 03/04/04 05:18 AM
TAucoin Offline OP
I installed the Pro-comp add-a-leaves about a month ago, and until tonight I had no problems with them. They creak and sqeak over any bump i hit and its pretty loud. i'm wondering if i can take it back apart and possibly grease them? if so what kind of grease should i use. Anything else to stop it? Thanks!
Re: Sqeaking Add-A-Leaves [Re: TAucoin] #411584 03/04/04 07:30 AM
azimuth Offline
Yep, that's what I did. I took some axle grease and schmeared it on the sides of the springs(don't need to take them apart. You don't even need alot. Then wrap the springs in duct tape to keep the dirt out while the grease works in. Drive around for a week or so and the grease will work itself in. then remove the duct tape and wipe the excess grease off the springs. All done!
7,62x51
time wounds all heels.
Re: Sqeaking Add-A-Leaves [Re: TAucoin] #411585 03/04/04 08:37 AM
kewlynx Offline
Scope out the Penephite over on this site; their Aerokroil is pretty good too Kano Labs
**ubi apis- ibi salus**
Re: Sqeaking Add-A-Leaves [Re: TAucoin] #411586 03/04/04 05:01 PM
Try some spray on dry graphite lube. It's a great lubricant and it contains no oil so it won't attract dirt.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.5977 MB (Peak: 0.6572 MB) Data Comp: Off Server Time: 2026-11-18 11:55:15 UTC
