80 amp fuse #411984 03/05/04 12:46 AM
toyrunner Offline OP
I have a friend that put his battery in
back-ass-ward <img src="/forums/images/graemlins/shocked.gif" alt="" /> No, it wasn't me!
Anyway, he was inquiring on how to remove the 80 amp fuse to replace it.
Anyone know the procedure. My shop manual isn't handy at this time.
Thanks
danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: 80 amp fuse [Re: toyrunner] #411985 03/05/04 01:17 AM
Esquire812 Offline
Its in a holder, release the clips with a skinny flat screwdriver and push it up through the housing. Or is that down through it? shooot....anyways its bolted to the wires with 7mm or 8mm bolts. Easiest access by unbolting the whole block from the inner fender, unhooking the other connector clips and going at it from the bottom.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: 80 amp fuse [Re: Esquire812] #411986 03/05/04 01:33 AM
SHAD Offline
You have to pull the mounts for the fuse box then loosen some wire up push the fuse up through then use a cross it to remove the screws that hold the wires to the fuse.
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: 80 amp fuse [Re: toyrunner] #411987 03/05/04 03:00 AM
It has a clip lock, just push it with a screwdriver, push the fuse and holder down. One bolt on each side. Should take about 5 minutes.
Re: 80 amp fuse [Re: toyrunner] #411988 03/05/04 03:03 AM
kewlynx Offline
Also as a precaution, check the B+ termianl on the alternator to make sure it's not burnt. Hopefully the fuse did its job <img src="/forums/images/graemlins/shocked.gif" alt="" />
**ubi apis- ibi salus**
Re: 80 amp fuse [Re: kewlynx] #411989 03/05/04 05:23 AM
Thanks for all the replies. Gonna tackle this tomorrow after doing a brake job on my sisters 82 pickup <img src="/forums/images/graemlins/sleeping.gif" alt="" />
Danny
1985 SR5 4Runner
4.7:1 single case
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6112 MB (Peak: 0.6809 MB) Data Comp: Off Server Time: 2026-05-29 19:54:56 UTC
