Removing fan clutch, what tools? #412446 03/05/04 03:43 PM
Jason_dup1 Offline OP
I know this is an easy change, I did it about 2 years ago. I just cannot remember what tools I need. I think it's only a wrench, right? Anybody remember what size the nuts are? I am only asking this so I can get the tools ready today while I'm at work, so I can get home and change this thing out.
Thanks,
Jason
1992 4runner, all stock, just got it. only 24k miles!!!!!!!!
1992 Toy Pickup V-6 Reg Cab
33 BFT AT/ko, 3 lift
230k miles
Re: Removing fan clutch, what tools? [Re: Jason_dup1] #412447 03/05/04 03:45 PM
toyrunner Offline
10 mm combination wrench, stubby and long
Danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: Removing fan clutch, what tools? [Re: toyrunner] #412448 03/05/04 03:48 PM
Thanks Danny.
I cannot remember if I remove the radiator, I did last time to flush everything out/change coolant and therm. Don't remember If I *had* to though.
Jason
230k miles
Re: Removing fan clutch, what tools? [Re: Jason_dup1] #412449 03/05/04 04:37 PM
4Crawler Offline
Remove the lower and upper fan shroud, usually gives enough room to get to the fan clutch.
Re: Removing fan clutch, what tools? [Re: 4Crawler] #412450 03/05/04 05:11 PM
javven Offline
Racheting wrenches (dog bones) kick hiney working on the front of a motor. Mine's a diesel so YMMV but I can get a good 1/4 swing on just about everything, PITA even with an offset or angled head wrench but with the rachets it's a breeze.
Even if you were just going to have three of them, you could get 10/12, 11/13 and... oh, probably 12/14 and it'd set you back less than $20. Anything bigger should really be done with a box-end wrench.
Change your oil hot and often.
07 Taco V6 4WD 5-Auto
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6070 MB (Peak: 0.6709 MB) Data Comp: Off Server Time: 2026-06-20 17:30:52 UTC
