Re: Best place to buy 15" chrome wheels and 33" tires combo ? [Re: pu12en12g] #413921 03/09/04 12:26 AM
Jonesy Offline
Well right now, it is the stock suspension, and within the last few days am experiencing some wavering / friction /pulling to the right at freeway speeds. I am hoping it's just a wheel bearing <img src="/forums/images/graemlins/pfft.gif" alt="" />
So I would like to fix that at the same time that I upgrade the suspension and wheels. I don't know anyone that I would trust to do it (the lift kit) correctly.
Here is another question: When I bought the Rodeo, they said one of the leaf springs was broken in the rear so will the upgraded suspension take care of that or will I need to buy a whole new OTHER set of rear leaf springs ? I see that the kits say "HELPER SPRINGS" ?
EDIT: Another stupid question but would you recommend a 2.5" exhaust cutout to free up the exhaust (I'm about to do a search on this anyways) ?
Any info appreciated ! !
If one of your leaf springs is broken I would go ahead and replace the whole pack. Darlington Offroad has a full new spring pack for sale.
I wouldn't have a shop do this install. Most of the shops that I talked to didn't like the idea of doing a T-bar crank to gain lift...however, that is the only option we have for a suspension lift. The lift kit is extremely easy, and if you get a new spring pack it is even easier. All you would need is a jack, some jackstands, and some wrenches(17mm, 14mm, 24mm, and 27mm are the ones I can think of off the top of my head.
Good luck
Steve
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: Best place to buy 15" chrome wheels and 33" tires combo ? [Re: Jonesy] #413922 03/09/04 01:29 AM
P
pu12en12g Offline OP
You guys kick serious ass ! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Ok I'm gonna get the wheel bearing ASAP after hearing that story on page 1 <img src="/forums/images/graemlins/shocked.gif" alt="" /> <img src="/forums/images/graemlins/shocked.gif" alt="" />. I'll get that installed first ASAP, probably tomorrow. I am having a hard time seeing the differences in these various lift kits from $600-$800. They all seem to include the same stuff, meaning that there should be "ONE" obvious best overall $$$ deal right ? I kinda like the calmini kit so far, with the new front upper control arms but is there another one I should look at that's better for the $$$ ?
Or is it based on my future goals ? Mainly this is my winter / daily driver, with most of the offroading will not include those trees and rocks like in your gallery, but more like mud, deep snow, and hills. BUT I will go with the bodylift too if that is just plain better (better ride / suspension) ? But then I would like to get one of those chrome side step things and 35" tires if I do that... <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
1999 Isuzu Amigo 4WD
Re: Best place to buy 15" chrome wheels and 33" tires combo ? [Re: pu12en12g] #413923 03/09/04 09:25 PM
P
Ok so the wheel / alignment guy didn't find ANY problems which would explain the wavering / friction I am feeling from the front right wheel (only occasionally, and only above 55mph). He said it isn't the wheel bearing, or the brakes. Now I am paranoid as hell.
I would suspect the tires, except the wavering / wandering only happens occasionally. They didn't find any alignment problems which would explain the symptoms.
They did swap the front tires, and a minor toe-in adjustment..
What do you guys think <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/shocked.gif" alt="" />
Re: Best place to buy 15" chrome wheels and 33" tires combo ? [Re: pu12en12g] #413924 03/09/04 11:01 PM
Rodeo Guy Offline
Hey whose blue rodeo is that in the first post? Never seen it before, pretty solid.
Hmmm don't know what to tell you bout the wandering problem. I woulda said wheel bearings, or somethin in the suspension, possibly wheels bent or tires out of round. But all that stuff I would think the shop should detect easily.
As far as lifts, some people think the calmini lift includes a bunch of stuff that isn't really necessary. Like the heavy duty torsion bars and cross brace. I would check out the Indy4x or DOR lifts. The lifts are pretty simple to install, maybe you can get one of us to volunteer and come help yah.
I just have 2 inches of suspension lift, via shackles and torsion bar crank/ balljoint flip. That cost me nothing. I'd like to add a couple things though like balljoint spacers, low profile droop snubbers, maybe another inch from add a leafs. You can buy all that stuff separately, which is good if you are on a tight budget.
And if you wanna buy your tires at the same place as your lift, indy4x does carry tires and wheels, he will mount em up balance and ship em to yah ready to be put on.
35's looks cool, but I just wouldn't recommend them if you want to do any real wheeling, they just put too much stress on everything. And with the 3.1 which you already feel is underpowered, you would definately definately need to regear, which is damn expensive.
Good luck!
Mike
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: Best place to buy 15" chrome wheels and 33" tires combo ? [Re: Jonesy] #413925 09/13/04 03:15 PM
P
Ok guys here is my problem.
One of my rear leaf springs is broken. I am ready to buy 4 wheels and 33" tires and a 3" lift. BUT where can I replace the leaf spring that is already broken.
Thanks ! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Best place to buy 15" chrome wheels and 33" tires combo ? [Re: pu12en12g] #413926 09/13/04 03:59 PM
4WDJOE Offline
Do you have a junk yard near you? The reason I ask is because you don't want to just replace one set of leafs with new ones. This will give you a higher ride on the new side(older springs have flattened out a bit).If you want to replace both sides then go with all new ones. I got 2 sets of Isuzu springs from a junyard near me for $36. That's pretty cheap if you ask me. I would also say that the lift will be really easy, most shops will kill you on labor costs. I second the PB Blast, that stuff is great. If you have it then wd-40 works pretty good too. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Big Swede here's your chance to get some 'Zu wrenchin' in. <img src="/forums/images/graemlins/smile.gif" alt="" />
97 Rodeo
Re: Best place to buy 15" chrome wheels and 33" tires combo ? [Re: 4WDJOE] #413927 09/13/04 04:53 PM
chasespeed Offline
As far as the trie wheel combo, I have found NTW , has sopme good prices on Swampers and crawlers.. dont know how that will help in your search...
Also indy4x , Matt, shoudl be able to help you with almost everything youneed..
Be patient with him though.. he was recently buried under A LOT of water from what I hear...
HTH
Chase
Chase
Re: Best place to buy 15" chrome wheels and 33" tires combo ? [Re: chasespeed] #413928 09/13/04 07:20 PM
P
Thanks guys.
What do you guys think of some 33x12.50 Super Swamper SSR Radials on 15" wheels ? <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6336 MB (Peak: 0.7491 MB) Data Comp: Off Server Time: 2026-06-22 06:13:44 UTC
