Air Filter #414536 03/09/04 06:55 AM
Been lookin at some options. Two questions...
1)Is it true K&N filters give you better gas mileage?
2) What custom filters are on your trucks and reviews of them.
Thanks
Re: Air Filter #414537 03/10/04 02:23 AM
From what I understand people using the K&N in the toyota have not seen any benefits from it, except that it is cleanable. Personally I use the Amsoil air filter. It is an oiled filter and can be washed every so often. Do some research on it on the forum, its been talked about several times.
Re: Air Filter #414538 03/11/04 08:44 AM
humanoid Offline
Hit up Gadget, he's dynoed everything and has all the results you will need for your question. www.gadgetonline.com
Re: Air Filter [Re: humanoid] #414539 03/12/04 12:29 AM
Dbryan22 Offline
I had the Amsoil filter. Just is a pain to clean and re-oil. Know what, the OEMs work just fine.
2001 SR5 4Runner 4x4
Performance considerations........... [Re: Dbryan22] #414540 03/12/04 03:59 AM
NHRA Drag teams spend 100's of thousands of dollars to
shave a tenth or so off their 1/4 mile times. Right????
You would never "feel" a change in your vehicle from an air
filter. It's one piece of a puzzle which would include
Airbox mods and a aftermarket exhaust system. One with out the other is only 1/2 the puzzle. You'll be moving more air through your oil coated filter than you would through a paper filter. Fact....more air equals more horsepower.
Blowers an superchargers do just that . Jamming huge amounts of air through the engine.
One little filter will only do so much. Kenny s>
Re: Performance considerations........... #414541 03/12/04 04:26 AM
azrain Offline
However, the results from simply opening up the intake are marginal, particularly on the 3.4. The real benefit is in increased fuel economy. I estimate a realized 6% overall gain in MPG. The caveat is that I use the "egg on the accelerator pedal" method of acceleration.
HP gains are imperceptible with any airflow mod on the 3.4 until you go SC. So many people have tried to prove that noticeable gains in performance are realized, only Gadget (that I am aware of) has proven by testing and objective evidence.
It sounds cool though.
Mike
A balancing act #414542 03/12/04 04:28 AM
The perfect air filter would trap 100% of debris but it
would let no air through. Today's filters use the oil and larger openings to maximize air flow and debris removal.
Don't forget air temerature. Cooler air makes for more horsepower. I believe they even make some sort of ice cooler for air intakes to create the cool air needed for peak performance.
Modifications to the average vehicle require many mods that will equal increased performance and fuel economy.
But in small amounts. Don't expect to lifting the front end with a air filter mod. Kenny S
AZRAin....like I said, air mods are only as good as your exhaust sytem. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: A balancing act #414543 03/12/04 05:57 PM
Here is a test of air filters from BobIsTheOilGuy.com that you might read and make up your own mind.
I read that once and had to do a Google search to find it again.
Re: A balancing act #414544 03/12/04 10:32 PM
i jsut got my amsoil filter and was curious whether i should blot some of the excess oil off before putting it in (like with a cleaning ) so i dont doul up the MAF
Re: A balancing act #414545 03/16/04 03:56 AM
FattyCBR Offline
Yes, just take two paper towels and sandwich the filter between them as you squeeze it between your hands together.
Milan
_ _ _ _ _ _ __ _ _ _ _ _ _
Support our troops!
'98 4R Limited
'82 Toy 4.3 TBI sold
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6216 MB (Peak: 0.7236 MB) Data Comp: Off Server Time: 2026-06-10 01:29:28 UTC
