Cheap 2 inch body lift #415333 03/10/04 07:31 PM
davidlong Offline OP
Back in the early 90's I had to lift my Raider 2" to get clearance for the larger bell housing on the Ford C6 transmission. I couldn't find a commercially available lift kit so I used the following to do it:
2 inch outside diameter PVC pipe cut to 2 inch length.
I went to the local hardware and found some 1 3/4" flat washers that fit perfectly inside the pipe. I stacked up 2" of washers and then ran a piece of 1/2 black water pipe through the holes in the washers. I then stuck the washer assembly inside the PVC pipe and siliconed the snot out of it to keep water out. End result was a solid 2" lift that I never need to worry about cracking or breaking like the fiberglass or urethane blocks can do. Even better the total cost to do the lift was only around 30 dollars. I also bought appropriate length hardened bolts needed to resecure the body to the frame.
Dave Long
Re: Cheap 2 inch body lift [Re: davidlong] #415334 03/10/04 08:31 PM
mrGUY Offline
Ouch! Better put a sign on the back stating that "this vehicle may roll over at any time." <img src="/forums/images/graemlins/shocked.gif" alt="" />
Well, I've seen worse. <img src="/forums/images/graemlins/notooth.gif" alt="" />
2008 Toyota FJ Cruiser
1989 SWB V6 Gone to 4x4 Heaven
Photo Pages
Semper Paratus
Re: Cheap 2 inch body lift [Re: davidlong] #415335 03/10/04 08:43 PM
Do you remember where you got the bolts? I'm having a little trouble there...
Re: Cheap 2 inch body lift [Re: davidlong] #415336 03/10/04 08:44 PM
DaphneD Offline
Roger Brown 4Crawler makes kits for our trucks. I've got the 1" lift kit on my truck and a few others have the 2" kit. I've only got good reviews.
4Crawler Custom Body Lift Kits
'89 Raider 3.0L V6 (6G72) w/ AW372L (A44DL) A/T
"The Millennium Falcon of automobiles"
Re: Cheap 2 inch body lift [Re: DaphneD] #415337 03/10/04 09:10 PM
DougH Offline
Mitsubishi Forum Moderator
Roger's kit was high quality. The blocks a great, strong, and self lubricating, they will never squeek.
The bolts and nylocs were also great.
Your lift blocks sound scary. Right up there hockey puck body lifts. But if it works for you it work for you. <img src="/forums/images/graemlins/notooth.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: Cheap 2 inch body lift [Re: DougH] #415338 03/10/04 09:26 PM
Remember, though, he did it 10 years ago...
Re: Cheap 2 inch body lift [Re: MontyMcV] #415339 03/10/04 10:17 PM
DougH Offline
Wow your right, I over looked that. I guess it has with stood the tests of time. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: Cheap 2 inch body lift [Re: davidlong] #415340 03/10/04 10:27 PM
LandRaider Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> on the cheap BL, but WHATS this about a C6 in your truck?? fill us in.
Re: Cheap 2 inch body lift [Re: LandRaider] #415341 03/10/04 10:33 PM
The C6 is hooked on one end to the NP205 transfer case (it's been awhile but I think that's the model) and on the other end to the Ford V8 302 that replaced the 2.6L. I'm going to do a post on that little project.
Re: Cheap 2 inch body lift [Re: davidlong] #415342 03/10/04 10:50 PM
LandRaider Offline
Awesome! I look foward to this!! more motor swapping stuffs!
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6427 MB (Peak: 0.7628 MB) Data Comp: Off Server Time: 2026-06-17 11:38:46 UTC
