Ring & Pinion Brand Suggestions #415588 03/11/04 01:24 AM
TyYota Offline OP
Any suggestions for what brand of Ring and Pinion I should use? Ive got prices on Quality Gear, and Neapco. Neapco comes in a little cheaper and I defenetly trust the shop that's selling them, but I don't want crap. One guy said he won't use Richmond gears. What do you think? I can't believe the prices for gears, they certainly are spendy!!
Tyler
'92 Toyota, 4x4, 22RE, winch, locker, 4.88's, 33's, 2" Body Lift.
Re: Ring & Pinion Brand Suggestions [Re: TyYota] #415589 03/11/04 03:51 AM
mt_goat Offline
I went with US Gear last time. No problems yet. <img src="/forums/images/graemlins/smile.gif" alt="" />
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: Ring & Pinion Brand Suggestions [Re: mt_goat] #415590 03/11/04 04:28 AM
Paul Elbisser Offline
if you have a V6 diff only 2 brands make true V6 gears. I once put in 4cyl gears, and they worked for a while, but eventualy blew. Long story, but I would only got true V6/turbo gears from now on in that diff.
Other than that, I have no clue on good or bad.
Paul Elbisser #3233
pastTLCAEastern Rep.
Pres Rice on the Rocks
www.riceontherocks.org
Re: Ring & Pinion Brand Suggestions [Re: Paul Elbisser] #415591 03/11/04 05:03 AM
dildinon Offline
which 2 brands make true v6 gears?
Davin Nisser
'94 Pickup Xtra Cab Deluxe 3.0 V6 5spd...'84 lwb frame swap with 2" body/drive train lift and solid axle in the works...
Re: Ring & Pinion Brand Suggestions [Re: dildinon] #415592 03/11/04 05:06 AM
larsdennert Offline
Precision makes good gears and also the V6 version.
Stay away from Genu-whine.
Re: Ring & Pinion Brand Suggestions [Re: dildinon] #415593 03/11/04 05:47 AM
Buster Offline
Precision, Richmond, and of course Toyota all make true V6 gears. I think I read somewhere that US Gear makes 'em too but not really sure.
Re: Ring & Pinion Brand Suggestions [Re: Buster] #415594 03/11/04 01:55 PM
mt_goat Offline
Yes, US Gear makes true V6 gears.
Re: Ring & Pinion Brand Suggestions [Re: mt_goat] #415595 03/11/04 05:08 PM
I have Precision and have been pleased for 25k miles so far.
Perhaps Yukon makes true V-6 gears as well, or at least that is what a bunch of 3rd Generation guys are running.
Set-up matters as much as brand, but there is a reason Genuine is guaranteed for life.
Re: Ring & Pinion Brand Suggestions #415596 03/11/04 06:16 PM
mt_goat Offline
I think Yukon just repackages the main manufacturers products in a Yukon box.
Re: Ring & Pinion Brand Suggestions [Re: TyYota] #415597 03/11/04 09:53 PM
AlaskaToy Offline
precision gear
AJ
93 Toyota, dana 60, 14-bolt
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.010s) Memory: 0.6336 MB (Peak: 0.7393 MB) Data Comp: Off Server Time: 2026-07-15 00:08:41 UTC
