2L Diesel Engine??? #415786 03/11/04 09:58 AM
RAZZMATAZ Offline OP
I just bought a 84 truck for the solid axle to do a SAS on my 87 4Runnner, bought it sight unseen the seller told me that it did have a comlete axle and a engine in it but was missing the trans a T-case.
When I pulled it home and opened the hood I was very suprised to find a 2L engine sitting in it.. Anybody know about this engine?? Does it make any power? Is it something I might want to use?? Is it something someone else might want to use??
Thanks
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
Detroit in rear, Lockright in front
35 MT/R
Rancho 9000
Jacobs ProStreet ign module and Ultra coil
1992 3VZ-E swapped in
Re: 2L Diesel Engine??? [Re: RAZZMATAZ] #415787 03/11/04 01:55 PM
these are (from what I've heard)very stout motors, but they have less power than the 22re. like most deisels they will(with the right care) last a very long time. they also made this motor in a turbo-deisel (2lte?). which supplies just as much if not alittle more power than the 22re. they also made a rare(not found in US)turbo-deisel the 3LT-ec? which is the 3.0L(I think) engine found in the larger trucks. the 3LT is the way to go and is the motor I plan on swapping into a something one day. it only takes $$ and luck to get one..........Karl
Re: 2L Diesel Engine??? #415788 03/11/04 08:53 PM
4
4runner4ever Offline
2L= 2.5L D 85 hp 165Nm
3L= 2.8L D 91 hp 188Nm
5L= 3.0L D ?
2LT= 2.5L Turbo 94 hp 215Nm
2LT-E= 2.5L electronic injection turbo diesel, 102 hp 260Nm
If it runs, it's easy to fit a turbo on a 2L. <img src="/forums/images/graemlins/smile.gif" alt="" />
Black '90 4R
SAS with LC80 coils and LC70 high pinion axle
LC80 rear axle, coils and locker
4.88 gears
2JZ-GE+turbo+intercooler
Re: 2L Diesel Engine??? [Re: RAZZMATAZ] #415789 03/13/04 10:14 PM
Does anybody know if thes will bold up to a W56 trans???
Thanks
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
35 MT/R
Rancho 9000
Re: 2L Diesel Engine??? [Re: RAZZMATAZ] #415790 03/14/04 05:25 AM
kyle-22r Offline
if it still has the stock bellhousing, it'll bolt right up to a w56, since that's what the motor came with
it won't work with a 22R bellhousing, you need one off a 2L
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6081 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-11-16 08:48:05 UTC
