Truck has been getting 17-18 miles per gallon with 40/60 city/highway driving on 89 octane (she used to ping on 87 - haven't gone back to 87 since adjusting valves and timing). I was hoping to get like 24 on the highway, but that ain't happening. Highway speeds are 70-80mph. I am about to (in two weeks) drive the truck load with all my crap and pulling a 4X8 utility trailer from NY to UT. I am concerned that the new BFGs is going to put me down to 16mpg and that is killing me!
What can I do to increase mpg - or is this what I should be getting? Could the removal of the cat converter have been a mistake? I have just one O2 sensor and that is before the empty cat. Maybe replace the O2 sensor. Thanks for reading
Unless you can discover mechanical probelms (like a tired O2 sensor, bad water temp sensor, low tire pressure, leaky injectors, etc.), you're pretty much stuck at your current mileage.
What you can change is your driving habits. Learn to squeeze fuel and you might pick up 10%.
Some Tips:
1. Accelerate gently and slowly. Installing a vacuum gauge can help train you by giving you feedback.
2. Anticipate slowing and decel way in advance (assuming it's safe and couteous to do so)
3. Keep your truck at the speed limit. There's that old law of kinetic energy which states that KE varies as the square of velocity. In English, this means that if you merely double your speed, your fuel consumption QUADRUPLES! That's right, increase from 40 to 80 MPH, and your fuel consumption will be 4 times greater. So, instead of 75-80, back it down to your local speed limit.
Cat removal won't hurt your mileage. A bed cap will trim a MPG or two. A lift doesn't help either.
Quick Question: Where are you located and do you have any use for your old cat? If not, I'm looking for a nice cat.
