Optima Battery Question #417441 03/14/04 03:10 AM
I have been searching all over the Web and hear conflicting stories about Optima Yellow and Red Top Batteries. I have a 91 Toy, 22re, stock alternator and a WARN 8000lb winch. The original battery just can't handle the winch so I was thinking of buying the Yellow Top. Is this the right battery? Or should I get the Red Top.
Thanks in advance!!
Jack
Re: Optima Battery Question #417442 03/14/04 03:45 AM
rob_dup1 Offline
i asked these guys a while back the same question and they
recommended yellow
remy battery
Re: Optima Battery Question #417443 03/14/04 04:24 AM
Hecubus Offline
Yellow
I've had it in my truck for over a year and a half. I'm running a big system, Driving lights, fog lights and handles the load very well. I can crank my system for over one hour and still have 11.5 volts to start the truck.
I've also had a yellow top in my Camaro for over 2years great there too.
Jed
88 SR5 Toyota Pickup 22re,TRD cam 4" Pro-comp, crappy superlift 4" springs rear, 1" body lift, 1.5" BJ spacers, 35x12.5 PJ Dirt grips, no locker yet =( SAS in the works
Re: Optima Battery Question #417444 03/14/04 05:08 AM
OOP'S Offline
Here is my choice!!!!!
ODYSSEY DRYCELL BATTERY - PC1200MJT, 12 Volts 630CCA, Reserve Capacity (Min.) 91, Hot CA @ 5 Sec. 1200, with metal jacket for protection from heat & SAE universal brass terminal, L-7.8125, W-6.5625, H-7.5625 (in.) - Automotive/Commercial û Heavy Duty Batteries û Three Year Warranty Add 0.75(in.) clearance for automotive terminals
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Optima Battery Question [Re: OOP'S] #417445 03/14/04 06:12 AM
i got a red in my bronco and it works fine but i have heard the yellow or blue are better for prolong loads when i go to a dual batt system its gonna be red and yellow
Re: Optima Battery Question #417446 03/14/04 07:02 AM
RAZZMATAZ Offline
I have had both the red and yellow top in my 4Runner(not at the same time)... I think I ran the red one in to the PS pulley on my rig.. the red top have a little more voltage and a little more CCA.. matter of fact my red top was proven to have something like 1300 CCA after a year of service.. I think that is 400 more than the manufacture claims.. I have a yellow top in there now, I haven't had the CCA checked since i bought it but it does fine.
One thing you might take into consideration is that the red tops have a 3 year FREE replacement while the yellow only have one year..
the blue tope are the same as the yellow or red depending on the part #.. I think the blue top with the dark gray housing is the same as the red top. and the blue top with the light gray housing is the same as the yellow top.. they just have screw on terminals one them..
HTH,
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
Detroit in rear, Lockright in front
35 MT/R
Rancho 9000
Jacobs ProStreet ign module and Ultra coil
1992 3VZ-E swapped in
Re: Optima Battery Question #417447 03/14/04 11:17 AM
ldivinag Offline
red top has longer warranty...
trust me... had both. doesnt make a diff.
get a higher output alternator. and just make sure you let the batt rest between winching...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Optima Battery Question #417448 03/14/04 08:36 PM
Brian894X4 Offline
I've run both batteries. The specs on the Optimas are very confusing, because they keep changing them. There used to be rated pretty high, but then they modified them and lowered the CCA and the capacity. I was told several different stories including that the new parent company required them to lower the specs for some reason, or that they no longer use virgin lead in thier batteries.
Now that I've looked at their specs, it looks like they changed back to the old ratings. So, I'll bet some of the batteries with the lower ratings are still on store shelves. Avoid any yellowtops with CCA ratings of 650. The orginal and current yellowtop rating is 750 and that is plenty to work a winch. The yellowtop and red capacity and CCA is pretty close, but the yellowtop has a slight advantage and will last much longer when repeatedly discharged. But it's also much more expensive than a red top.
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.013s) Memory: 0.6195 MB (Peak: 0.7170 MB) Data Comp: Off Server Time: 2026-11-18 03:32:05 UTC
