Anyone have experience with a hand throttle?
#417492
03/14/04 06:18 AM
I have all the parts sitting around, most of 'em universal though the lever is from an old CJ. I can rig a way to mount it to the carb and run the cable through the fire wall and mount the lever on the shifter.
Mainly what I want to know is if anyone has any real world experience on the trail with one either in a Zu or other rig. Does it really help with the three pedal dance on hills if you stall? Any major cons I should be aware of? I did a search but didn't find a lot of opinions and that is what I am looking for, a general consensus of them. Chime in if you had any run ins with them, good or bad.
Thanks in advance Craig
1986 Isuzu Trooper 2dr LWB 1999 Saturn SL
Re: Anyone have experience with a hand throttle?
[Re: wb86]
#417493
03/14/04 12:21 PM
I have a hand throttle on my riding lawn mower. It has a turtle for slow and a rabbit for fast. I have it set to rabbit all the time.
It really helps when starting on hills, especially since the clutch and the brake are the same pedal, I only have that one pedal to worry about.
HTH Mike
[Re: wb86]
#417494
03/14/04 02:52 PM
http://www.4x4wire.com/forums/showf...&o=&fpart=1&vc=1Check out his sig for the pics. It's in the "Cool, DIY Mods #2" folder.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5944 MB (Peak: 0.6479 MB) Data Comp: Off Server Time: 2026-06-07 05:02:27 UTCValid HTML 5 and Valid CSS
