RUSTED CALIPER PINS #420594 03/19/04 05:36 PM
Hey guys,
Just did new rotors and repacked everything up front...trying to do new pads but the pins that hold the pads in are rusted bad. Tried to pound them out with no luck and am looking for other tricks! Would it be safe to heat them with a torch or would this wreck the caliper pistons/brake fluid??
Many thanks
Benny
Re: RUSTED CALIPER PINS #420595 03/19/04 06:16 PM
Chris V Offline
Try cleaning the rust off with a wire brush
1996 T100 SR5, 4" Procomp Stage2,
33x12.5x15 tires
http://members.cardomain.com/chris_t100
Re: RUSTED CALIPER PINS #420596 03/19/04 06:55 PM
I would try soaking them overnight in Liquid Wrench or some other penetrating oil first to see if that loosens them up.
Re: RUSTED CALIPER PINS [Re: Chris V] #420597 03/19/04 07:51 PM
surlynkid Offline
it sounds like he cannot get them out to start with. i always grease mine before i put them in. ford sells a special grease just for their pins althought the pins on my 89 bronco were a lot different.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: RUSTED CALIPER PINS #420598 03/19/04 07:52 PM
I soaked them with penetrating oil last night....I'll try the wire brush....no opinions on the torch?
Re: RUSTED CALIPER PINS #420599 03/19/04 09:11 PM
I just did mine a couple weeks ago. What should have been about an hour job, took several hours and was a PITA! I used a lot of PB Blaster. Make sure you hit the pins a couple times after spraying them, the vibration seems to help work the penetrating spray in. I used a punch and I was careful not to 'mushroom' the end of the pin. It seemed to help to hit the pins from both sides. Once the pin moved a little, I soaked it and was able to finally remove it. My calipers were replaced a few years ago, so I don't know why the pins are so hard to remove.. good luck, they'll come out eventually..clean the pins and use lots of penetrating oil.
Re: RUSTED CALIPER PINS [Re: surlynkid] #420600 03/19/04 09:15 PM
Chris V Offline
I meant try brushing some of the rust of before beating on them.
33x12.5x15 tires
Re: RUSTED CALIPER PINS [Re: Chris V] #420601 03/19/04 11:37 PM
These things weren't budging so I torched em....worked good, you just have to be real careful that you don't get too close to the piston boots...I just kept spraying them with water. Anyway I got it all back togather with the proper anti-seize and it seems to be working great!! Thanks for the advice!!
Benny
Re: RUSTED CALIPER PINS #420602 03/21/04 01:56 PM
RWD Offline
I live where they salt the roads and my pins were rusted solid. Now way of getting them out in one piece. I tried penetrating oil to no avail. I ended up breaking them off and using a center punch to pop them out. I now use anti seize on them .
Re: RUSTED CALIPER PINS [Re: RWD] #420603 03/22/04 02:49 AM
mainer Offline
put "never sieze" on them... its a silver liquid kinda stuff comes in a small silver can with a brush type thing to apply it...
i put it on my pins and have never had any trouble since, you may also want to spend the $5 and get new pins if you bent or mushroomed yours taking them out.
i also put the never sieze on my lug nuts every time i have them off. stuff works excelent and makes it so they dont rust on.
just dont get it on your clothes because it wont!! come out
00 tacoma 4x4 ex-cab stock 193,000 and counting
85 long bed pickup 4x4 frame off restoration. rear lock rite 31's 268,000 miles
51 cj3a stock everything orginal 2500 original miles
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6311 MB (Peak: 0.7524 MB) Data Comp: Off Server Time: 2026-11-16 08:46:32 UTC
