Hydraulic Clutch Conversion #422805 03/23/04 02:53 PM
doc long Offline OP
ok, hit a tree, replacing my frame. (83 cj7,258,t5)
so on the "while i'm at it list" i'm considering
changing over to a hydraulic clutch and i'm wondering what some of the advantages and disadvantages are. also is it as simple as removing the linkage and installing the master and slave or... are there other changes that would have to be made. i looked up the parts and it looks like about $160.
did cj's ever come with hyd. clutches? the hole is there on the firewall but i've never seen one with it.
thanks,
Brian <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Hydraulic Clutch Conversion [Re: doc long] #422806 03/23/04 08:37 PM
BigJim Offline
Whatever you do, do not get the slave cylinder with the hole in it for the tranny shaft to pass thru. I think whatever you have now is far better that that peice of *****! I understand the very late models have a slave cylinder that you might like.
Big Jim
Re: Hydraulic Clutch Conversion [Re: BigJim] #422807 03/24/04 04:00 PM
doc long Offline OP
actually, i should have been more specific. i'm talking about the hydraulic kit to replace the linkage. as far as i can tell it just bolts in place of the factory linkage. like this.. http://www.partsmikeparts.com/ClutchSlaveKit.htm
thanks,
Brian
Re: Hydraulic Clutch Conversion [Re: doc long] #422808 03/24/04 05:34 PM
ouch... 230$ i wouldn't spend that much unless you were 100% shure it would work forever. why not go down to a junk yard and liberate one from there?? that way if you are wrong you are only down 100$ or less.
Re: Hydraulic Clutch Conversion [Re: doc long] #422809 03/24/04 05:36 PM
BigJim Offline
Howdy Dock
I think you should look very closely at your exixting setup before purchaseing somethoing like that... Look to the clutch pedal and anywhere you might have to modify or maybe completely re do to make such as that work
Big Jim
Re: Hydraulic Clutch Conversion [Re: BigJim] #422810 03/24/04 05:46 PM
doc long Offline OP
yeah, i wouldn't actually buy one from there. i was just using that as an example. there's a write up hear..
http://www.monsterslayer.com/jeep/HydClutch/HydroClutch.htm
it doesn't seem like a big deal to mod the pedal assembly.
i'm just wondering if anyone has any experience with it vs. keeping the mechanical setup. i know the mechanical setup wears out but the parts for the whole linkage are a third of the hyd. i'm probably gonna stick with stock right now since it's working fine and i really want to get the jeep back together. (2 frame ups on the same jeep in 2 years...that's gotta be some kind of record <img src="/forums/images/graemlins/shiner.gif" alt="" />)
thanks,
Re: Hydraulic Clutch Conversion [Re: doc long] #422811 03/24/04 06:02 PM
if you are doing a frame up you might be able to cut the clutch area of the firewhall out of a YJ and take its clutch pedal and weld it all together then i know you can buy a hydrolic master for under 100$ new. then all you need is to mod the tranny.
Re: Hydraulic Clutch Conversion [Re: doc long] #422812 03/28/04 05:24 AM
all you need is the clutch assemblly out of a cj 7 mine has stock hydraulic clutch thats the hole in the firewall you mentioned is for should bolt right in to that t5 not sure about clutch pedal but the worst u should have to do is drill a hole in the pedal arm to bolt up the master cylinder pushrod to let us know how it comes out if you try but i know itll work by the way the parts i know work are out of an 86 cj7
Re: Hydraulic Clutch Conversion #422813 03/28/04 06:48 AM
I went to an auto parts store (O'Reillys) and bought the whole set up and a piece of brake line for about $110 for an eary '80's CJ with the 4 cylinder motor.
Cut a hole in my firewall, drilled mounting hole's, drilled a hole thru the clutch pedal and mounted the rod, (rod already has a big hole in it for this), with a bolt, washers and a cotter pin.
Had to do a lot of measuring to put the clutch master cylinder in the right place so the rod came thru the firewall and set right up next to where I wanted to mount it to the pedal arm.
I love it, before with the solid linkage, when I had the frame all twisted up, the clutch wouldn't work, the pedal would be almost to the floor, now I have no problem at all.
Only problem I really had was I did not have the rod that goes to the clutch fork, so I just improvised with the one on the manual setup.
It's not a hard upgrade at all, and it's well worth it.
Re: Hydraulic Clutch Conversion #422814 03/28/04 06:52 AM
I just noticed you have an '83, thats the year setup I bought (for the 4 cylinder motor), you already have the hole in the firewall too so thats good, heck your pedal might already have the hole in it too!
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6305 MB (Peak: 0.7545 MB) Data Comp: Off Server Time: 2026-11-17 11:04:59 UTC
