Part number for TPS.... #423183 03/24/04 04:08 AM
gcinque Offline OP
Does anybody know what the factory part number for the tps for my 1989 4Runner is? According to the sticker on the door jamb the production date is 10/88. The tps currently in the truck has the following part number:89452-28030. I just purchased a new one and they sent me : 89452-20050.
Would I still be able to use the new one?
Thank you.
gcinque
03 Tacoma Xtra cab 4cyl 5spd
89 4Runner/Jasper reman 22RE/Auto SOLD
98 Tacoma Xtra cab 4cyl Auto SOLD
Re: Part number for TPS.... [Re: gcinque] #423184 03/24/04 04:46 AM
Esquire812 Offline
As long as the plug/connection matches the existing TPS on your truck now, then dont worry about it. Part numbers change over the years...but the parts remain the same. Only concern would be if they sent you the rectangular plug TPS used through 88'...that one wont work for you.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Part number for TPS.... [Re: gcinque] #423185 03/24/04 12:37 PM
G
GeriatricToy Offline
As always, I have to agree with Darin. If the plug configuration is the same, slap 'er on. The screw location (width) didn't change, nor did the total resistance value of the potentiometer. I bought a brand new one on e-bay which had a different part# for five bucks, works fine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
2000 Tacoma SR5 - Bone stock 'cept a little bling.
2000 Tacoma SR5 - Bone stock.
Re: Part number for TPS.... [Re: GeriatricToy] #423186 03/24/04 02:49 PM
gcinque Offline OP
Thanks for the input guys. That did occur to me but I just wanted to make sure there was no other reason. Last night I started to remove the old tps and stripped the <img src="/forums/images/graemlins/angry.gif" alt="" /> philips head screw!! Now I really need to use the noggin to figure out how to remove that darn screw.
Thanks again!!
gcinque
Re: Part number for TPS.... [Re: gcinque] #423187 03/24/04 03:51 PM
G
Quite simple actually. You may want to remove the throttle body to this (recommended anyway to change the TPS). Cut a straight slot across the thread with maybe a dremel tool and us a flat head head screwdriver and spin that puppy right outta' there <img src="/forums/images/graemlins/kewl.gif" alt="" />. Replace the screws with allen head. They're either 6mm or 8mm,(I don't remember).
Post deleted by little_joe [Re: gcinque] #423188 03/24/04 07:32 PM
Re: Part number for TPS.... #423189 03/24/04 07:38 PM
Esquire812 Offline
Side note for folks with pre-89 22R-Es. If you cant find a good used TPS and are scared of what Toyota will do to your backside ordering through them...use an alternative source Not sure of the engine model, Antelope Butt... Mazda 929's from the mid to late 90's use the same TPS as pre-89 Yota 22R-Es. Made by NipponDenso with a Mazda part number obviously, but the innards, exterior and resistance values are the same! So keep that in mind next time your perusing the local boneyard...mazda parts generally are cheaper too. LOL
85' Sillyca 22R-Esq
Re: Part number for TPS.... [Re: gcinque] #423190 03/24/04 11:47 PM
toowacky Offline
gcinque,
89452-28030 supercedes to 89452-20050. See my TPS post.
Tom
1988 4Runner 22R-E W56
1989 4Runner 22R-E A340
1995.5 Rodeo 3.2L 5spd
Re: Part number for TPS.... [Re: toowacky] #423191 03/25/04 01:47 AM
gcinque Offline OP
I knew I saw that post somewhere! Next time I'll print the post before I do the work.
I think I'll do as suggested by 2Bigblue2 and remove the TB, while it's out I'll give it a good cleaning.
Thanks everyone for your help <img src="/forums/images/graemlins/cheers.gif" alt="" />
gcinque
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6252 MB (Peak: 0.7241 MB) Data Comp: Off Server Time: 2026-06-07 11:27:49 UTC
