Brakes Qestion? #423476 03/24/04 04:59 PM
G
GMJK86SR5 Offline OP
My brake pedal would go to the floor so I changed the brake master cylinder and bleed the brakes and they firmed up. Now it is doing it again. The pedal goes almost to the floor and then grabs, and stops the truck? Any suggestions on what it could be?
I need new front pads, but the rear shoes looked good, and the rears seemed adjusted correctly.
Mike
Re: Brakes Qestion? [Re: GMJK86SR5] #423477 03/24/04 06:18 PM
Are any of the calipers leaking fluid?
Re: Brakes Qestion? #423478 03/24/04 07:14 PM
G
aNot that i know of. Now this morning, pedal was firm and high. seems like the brake master cylinder again? Also no fluid loss from the brake master cylinder.
Re: Brakes Qestion? [Re: GMJK86SR5] #423479 03/24/04 08:04 PM
anthony1 Offline
Isn't there a vacumm line that goes to the master cylinder?
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Brakes Qestion? [Re: anthony1] #423480 03/24/04 08:36 PM
Red_Chili Offline
Toyota Section Staffer
No, that goes to the vacuum booster.
You could have an internal leak in the master cylinder, which could behave as you describe. It is not uncommon for master cylinders to fail right after bleeding- the reason? Using pumping to bleed the brakes sends the piston seals into a rough, contaminated area in the master cylinder, damaging them. It doesn't take long after that. Ask me how I know... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
That's why I really like pressure or vacuum bleeders so much.
-Bill
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6042 MB (Peak: 0.6636 MB) Data Comp: Off Server Time: 2026-11-17 11:24:29 UTC
