1st gen 4Runner rear window ? Roger B. ?? #424223 03/26/04 01:14 AM
fourwd1 Offline OP
I need to roll-up the rear window while the tailgate is down to access the nuts holding the tag light/rear switch housing, but an interlock prevents this. The sensor appears to be in the rear switch I am trying to get to. Anybody know a way to bypass that sensor?
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: 1st gen 4Runner rear window ? Roger B. ?? [Re: fourwd1] #424224 03/26/04 02:21 AM
Esquire812 Offline
While Im not 4Crawler...I have pretended to be him on TV <img src="/forums/images/graemlins/smile.gif" alt="" />
Hell, grab your battery, couple of leads, and hard wire the motor. Thats how Ive been actuating mine until I get the switch problem worked out. Set of aligator clips on 12" of wire, clip onto the terminals in the connector, touch the other ends to + and -, reverse the wires to get opposite direction.
Other alternative is to unbolt the motor from the regulator, this allows full motion of the regulator by hand.
Be careful doing this though or you will be searching replacement parts. There is a hole in the arms and main body of the regulator that you can pin for safety and removal purposes.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: 1st gen 4Runner rear window ? Roger B. ?? [Re: fourwd1] #424225 03/26/04 02:49 AM
BigBri Offline
The interlock is the left tailgate latch. Just open the tailgate, rotate the latch all the way in, as if the tailgate was closing, and use the key to raise the window. Be careful to support the window as it comes out. To close the tailgate again, lower the window and use the handle to "open" the tailgate, which will let the latch pop back to open. hope this made sense.... Brian.
Re: 1st gen 4Runner rear window ? Roger B. ?? [Re: BigBri] #424226 03/26/04 02:58 AM
Dok Offline
You can also get it from the inside, just roll the window almost all the way up until you can get to both nuts that hold the switch/plate light panel on. Let me know if you need a picture, I'll try to dig one up when I get home (if I ever do <img src="/forums/images/graemlins/rolleyes.gif" alt="" />)
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: 1st gen 4Runner rear window ? Roger B. ?? [Re: Dok] #424227 03/26/04 03:15 AM
fourwd1 Offline OP
Doh
Hot wire the motor, do it inside the truck, sometimes the obvious totally escapes me <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Thanks for the ideas, they'll work <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6061 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-07-09 22:20:14 UTC
