89 Montero Service Manual?......Fast Idle Problem help! #424429 03/26/04 03:35 PM
StreetbikeDepot Offline OP
At some point I downloaded a service manual here on the forum, but I don't seam to have the MPI Fuel system section for it. My Montero is Idling fast, about 2500 on start up and the ICS (IAC) drops it down to 2000 or so after warm up. I've checked the TPS, it checks out ok, I checked for vacuum leaks, and I even pulled the throttle body, cleaned it and reinstalled, still nothing. I even fidled around with the TPS and still it avaids me. I'm wondering if my MAF sensor is screwing up. It runs perfectly fine down the road, just idles fast. Any help would be greatly appreciated.
Re: 89 Montero Service Manual?......Fast Idle Problem help! [Re: StreetbikeDepot] #424430 03/26/04 08:48 PM
IdahoJack Offline
First try cleaning the throttle-body and ISC per this link:
http://www.4x4wire.com/mitsubishi/tech/throttle_body/
While you have the ISC disconnected, you might as well check its coil resistance per this link:
http://www.stealth316.com/2-isc-iac.htm
Let us know how it runs after doing the above.
90 Montero, 2dr, AT, V6, LSD, AC, KYB shocks, bouncy seat, 182K miles, JDM engine, 87 Starion seats, tow hitch
http://www.geocities.com/idahojack03/Index
Re: 89 Montero Service Manual?......Fast Idle Problem help! [Re: IdahoJack] #424431 03/27/04 01:30 AM
Thanks for the info, I have already cleaned the ISC and the throttle body. I didn't check the coils, only because it steps down fine during warm up. It'll drop the RPM 500-700 rpm.
Re: 89 Montero Service Manual?......Fast Idle Problem help! [Re: StreetbikeDepot] #424432 03/27/04 02:21 AM
DaphneD Offline
I have a copy of the MPI chapter of the service manual in .pdf - lemme know if you want it and I'll put it up for you. <img src="/forums/images/graemlins/wink.gif" alt="" />
-DougB
'89 Raider 3.0L V6 (6G72) w/ AW372L (A44DL) A/T
"The Millennium Falcon of automobiles"
Re: 89 Montero Service Manual?......Fast Idle Problem help! [Re: StreetbikeDepot] #424433 03/27/04 12:57 PM
My '91 did the exact same thing. I replaced the ISC and it fixed it. It cost about $300.00 or so from NAPA. You may want to read your computer codes before playing the parts changing game. There should be some old threads on computer codes in the archives.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6047 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-06-10 06:07:54 UTC
