Front Driveshaft Recommendation #424447 03/26/04 04:51 PM
ad54runner Offline OP
I dropped off my truck to have the crossover steering installed earlier this week. I removed the front driveshaft before I took it up there. After looking at the shaft more closely it looks like at some point the factory '85 driveshaft has been replaced with one from an '86. I have done the searches here and see that the later shafts don't have as much flex in the cv joint. I saw the article about modifying them to increase movement, but before I do anything I want to check out my other options. The shaft will be going on a 1985 4Runner with the Marlin crossover steering. The front axle is moved forward ~2" with a hybrid set of Downey/stock rear springs. They will be mounted with a set of banana shackles that are 2" longer than stock. I also have a 2" drivetrain lift affecting the needed length of the shaft and only have a single xfer case. I have a second t-case and the crossmember is set up for a second case in the future, however it will likely be another year before I try to finish that. I have read the arguement back and forth about cv vs a u-joint at either end. I will need to drive the truck in four wheel drive at highway speeds. I can't find anything as far as cost of driveshafts.
I guess I would like to know if it would cost more to have a completely new shaft built or if lengthening and adding a longer slip joint to the one I have will be cheaper. All of the driveshaft places I have found have to have exact specs to give me a price. At this point I don't know what my specs are until I get the truck back with steering installed and I still need to get the shackles on there.
I apologize for the length of the post, but this whole driveshaft thing seems very confusing and I am frustrated that after all this I will have to go through it again when I go to dual cases.
Chris Sutton
Golden, Colorado
1985 Toyota 4Runner - Longfields, 5.29's, EZ Locker F/R, Marlin X-Over, Rancho 99012's, 35" BFG AT KO, 414K miles.
1996 FZJ80 stock with 191K miles.
1980 FJ40 stock with 85K original miles.
Re: Front Driveshaft Recommendation [Re: ad54runner] #424448 03/26/04 05:04 PM
4Crawler Offline
If you want to drive at high speed in 4WD or at least with the front hubs locked, run a CV shaft, otehrwise u-joints are fine for a trail rig. Send the old shaft off to High Angle Driveline, Jesse can open up the CV and put a long slip yoke on it and it'll run about $300. New CV shaft will be in the $400+ range. New CV joints are expensive.
Re: Front Driveshaft Recommendation [Re: 4Crawler] #424449 03/26/04 05:19 PM
Sounds like modifying the shaft I have is definitely cheaper. Thank you for the heads up Roger. I will check into local places to compare to the place you listed. Once you get started on these things it just never ends, does it? 4x4 = $X$
Chris Sutton
Re: Front Driveshaft Recommendation [Re: ad54runner] #424450 03/26/04 05:45 PM
Red_Chili Offline
Toyota Section Staffer
Chris, without a doubt the best place locally is Rocky Mountain Driveline. He can open up your CV or use it as a core for a good reconditioned Toy CV. One thing to be certain to do, the guy there has a liking for domestic yokes and ujoints. Specify and demand Toyota and he will do it for you.
I talked with Mike and let him know you were frustrated trying to contact him. The phone is becoming a bottleneck for him, but that is not an excuse, but he said he never got a message. You can drop off your driveshafts and Mike can turn them around in a day, using RM Driveline, for the same cost. The advantage is, he is closer to you and RM Driveline knows if they use anything but Toyota Mike will refuse it. They have a good working relationship which can work to your advantage.
As far as redoing the shafts, yes, its maddening. One option if a dual case is soon, is to do a temporary square tube shaft yourself, and open up the CV joint yourself. Just don't drive highway speeds in 4x4 till you get the dual cases and the nice shafts. Make it long enough, and you will have an emergency spare. Erik B. did a good article on the CV mods, in the Toyota tech section here.
-Bill
Re: Front Driveshaft Recommendation [Re: Red_Chili] #424451 03/26/04 06:39 PM
Thanks for the info Bill. I was just checking over on Colorado4x4.org for a shop recommendation, but going through a "toyota only" shop is probably a good idea. Does Roger's number sound right for how much I should expect to pay through Mike? Would I still need to take measurements or can they do that down at ORS? I haven't been down to their new shop. Is it easy to find? I got a card in the mail and it looks like it is just off the railroad tracks east of Wadsworth. I think I have been back there to the Fedex depot.
I don't mean to whine about the cost, but when you first get into this crossover thing you look at around $400 for the kit and then the steering box. I didn't want my first welding project to be beefing up the frame to mount the box, so I had to add that plus install. I needed to move the axle forward to fit the 35's. Longer shocks needed the shock mounts moved plus longer brake lines. I still haven't gotten into the u-bolt flip or new bumpstops. With another $300 for driveline mods I am getting close to $1500 to get my crossover steering purchased, installed and fully functional. I just figured for anyone else looking to do this they should be aware that it affects so many things.
Chris Sutton
Golden, Colorado
Re: Front Driveshaft Recommendation [Re: ad54runner] #424452 03/26/04 08:18 PM
Red_Chili Offline
Yeah, I think Roger's number is about the going rate. Any shop should be able to measure it, if you want that added confidence.
At least you aren't looking at doing BOTH shafts with the crawl box. I am finding with a 3.4 V6 swap into an 87 I-4, the drivetrain MUST be moved ~3" forward. Gives me pause, on top of all the other work that would be involved. Heck, its only sweat, steel and green, how hard could it be? <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
The new ORS location is a little obscure.
map lifted from his site
You can get there via Wadsworth, north from I-70 to 52nd, east to Marshall, thence north. The street takes a bit of a jog east, that would be 56th. Mebbe 3/4 block east of there, on the south side, he is in the southernmost space in the industrial building. Give him a call yet? He can tell you what their arrangements are, I just know what I did to get my shafts (direct the second time).
Good points on the crossover costs. A lot of folks claim an 85 is soooo much easier to build up than a SAS conversion, your costs give the lie to that approach if you want one that can crawl and is built hell for stout. Think about beefing the front spring hangers while you are at it. One advantage remains: the arch of the frame allows more up travel than a SAS, with less lift. Lemme tell ya, a welder more than pays for itself with these things.
I'd bet you'll be pleased when you are done.
-Bill
Re: Front Driveshaft Recommendation [Re: Red_Chili] #424453 03/26/04 08:44 PM
I sent him a lengthy e-mail before lunch. I don't know why he didn't get the last couple I sent him. I even sent one of my request to his IT guy and he responded that he had forwarded it to Mike. We will see what he says. I will probably call him next week if he doesn't respond to my e-mail after I pick up my truck from the shop in Boulder and get the shackles mounted up front. That way it should be put together for measurement purposes.
Chris Sutton
Golden, Colorado
Re: Front Driveshaft Recommendation [Re: ad54runner] #424454 03/27/04 01:32 PM
Red_Chili Offline
Email? That's why. He hardly checks it. He's busier than a fox in a henhouse and devotes his time to the phone or meching. I still have an email in his inbox from a couple weeks ago he hasn't seen - about how you tried to contact him!
Jim Sanville hardly checks his either, and his wife is a web developer or something. Webophobia I guess. At work I have been known to email somebody on the same floor... <img src="/forums/images/graemlins/lol.gif" alt="" /> (Hey, don't pick on me, I have a record of what they wanted me to do, in case I need to refer to it later...)
-Bill
Re: Front Driveshaft Recommendation [Re: Red_Chili] #424455 03/31/04 03:57 AM
So I talked to Mike at ORS about a front driveshaft and the numbers he is giving me are much higher than are posted here. He said that it would be in the $350 range and that I would have to have an '85 core. Yota Yard sells the '85 shafts for $125 without a core, so that puts me at $475 for a rebuilt shaft. That is just way too rich for my blood. It was a stretch for me to pay for the crossover steering at $400 and now with the FROR pitman I am at $535 plus shipping for the crossover kit.
Has anyone used the driveshaft kit from Marlin
http://www.marlincrawler.com/shaft.html
or Allpro?
http://www.allprooffroad.com/driveline.html
It is $189 plus shipping. I would hope that it would be cheaper if I did my own work on the cv joint
http://www.4x4wire.com/toyota/tech/cvmod/
then I might be able to get it done for less than $300. I am curious if anyone has used this kit. Is it easy to do yourself? I assume that once you cut off the stock slip joint and weld the new slip joint on then all you need to do is have it balanced. I am so frustrated by paying this shop to put my crossover steering on without even checking to see if the pitman arm would clear the tie rod that I am bound and determined to do my own work from now on.
Chris Sutton
Golden, Colorado
Re: Front Driveshaft Recommendation [Re: ad54runner] #424456 03/31/04 04:33 AM
4Crawler Offline
I think High Angle Driveline gets around $300 for a long travel front shaft built off of a stock front shaft. I had a pair of shafts built at Paradise Driveline (shop owned by Jesse's dad and where HAD got started) and they ran right at $300/ea. That was about 3 years ago, so prices likely have increased since then.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6504 MB (Peak: 0.7808 MB) Data Comp: Off Server Time: 2026-11-17 06:25:05 UTC
