No spark, replace computer, no spark, replace coil and transistor no spark. Resolution #425024 03/27/04 11:05 PM
Mendel Offline OP
Subject line pretty much sums it up. My truck suddenly quit almost a month ago with total loss of spark. The computer appeared bad and it was sent to AvPro. They sent a replacement so they must have deemed it to be bad.
This didn't fix the problem.
The ignition transistor appeared bad and so it was replaced. The ignition coil was iffy so it was replaced. I still have no spark.
Any ideas on where to go from here? I don't see how it could be distributor related since the distributor is down-stream of the coil and there is no spark coming from the coil.
Any thoughts at this point are appreciated.
1991 Montero LS, fading red paint
Front and rear limited slip differentials
95 SR Rear Springs, torsion bar crank, 137,650 miles
33x12.5 ProComp Mud Terrains, Bushwacker Fender flares
3 litre V6 with new heads
Re: No spark, replace computer, no spark, replace coil and transistor no spark. What now? [Re: Mendel] #425025 03/27/04 11:57 PM
KrzyDav Offline
It sounds like the module inside the distributor. This is what everybody goes thru when it goes,, they buy the ECU, ouch.
Some of these modules are available with research , without buying the whole 500$$$ from the dealer.
I'm research all these modules to try to get part # so no one has to buy the whole dist . from salvage or dealer. The plastic of the mod cranks from age degedation, so junk yard one won't last long.
Keep in touch with me I'll try to find out more.
Junk yard dog
dave h.
Re: No spark, replace computer, no spark, replace coil and transistor no spark. What now? [Re: KrzyDav] #425026 03/28/04 12:39 AM
Lloyd Swartz Offline
Also inspect the timing belt through the inspection cover. Same thing happened to me on my 93. Luckilly I inspected the belt first and found it broken.
Re: No spark, replace computer, no spark, replace coil and transistor no spark. What now? [Re: Lloyd Swartz] #425027 03/28/04 01:35 AM
Lloyd -- IsnÆt the distributor driven by the camshaft? If true why not just pop the distributor cap and see if the rotor turns? If it turns wouldnÆt that provide evidence that the timing belt isnÆt broken?
Re: No spark, replace computer, no spark, replace coil and transistor no spark. What now? [Re: Lloyd Swartz] #425028 03/28/04 01:54 AM
Mendel Offline OP
Timing belt was the first thing we checked. It looks to be fine. It only has about 5000 miles on it.
How could it be the distributor module if there is no spark reaching the distributor? I would think if it was the distributor that you would have spark from the wire coming off the coil, but have no spark at the plugs. Right? Or am I missing something here. I have so spark from the wire coming from the coil that is going into the distributor.
I'm thinking that maybe the computer from AvPro is not functioning properly. Apparently it is not sending the all OK signal. It's not sending error codes either, though.
Re: No spark, replace computer, no spark, replace coil and transistor no spark. What now? [Re: Mendel] #425029 03/28/04 02:18 AM
The distributor performs two separate but related functions. One is to trigger the coil to spark this is the job of the ôdistributor moduleö. The other is to distribute said spark too the correct cylinder this is the job of the cap and rotor.
ED
Re: No spark, replace computer, no spark, replace coil and transistor no spark. Resolution. [Re: Mendel] #425030 03/30/04 07:00 AM
Mendel Offline OP
Well we borrowed another Montero from a fellow board member <img src="/forums/images/graemlins/cheers.gif" alt="" />, pulled the computer out of that Monty, put it in mine and she fired right up. The rebuild of the ECM by AvPro did not correct the original problem. The computer was still not operating. I'll be sending it back to Florida again tomorrow morning.
Apparently AvPro checks the circuits that appear to be fried and were repaired but they have no way of verifying that the computer is operating as it should. In this case, there must be something damaged that they missed. Something to keep in mind if you have your computer refurbished. Especially keep this in mind if you get it back and your truck still won't spark. Don't assume it must be something else that is broken. Your ECM might still be dead. <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: No spark, replace computer, no spark, replace coil and transistor no spark. Resolution. [Re: Mendel] #425031 03/30/04 07:15 AM
I hope your ISC didn't re-fry your ecu.
Re: No spark, replace computer, no spark, replace coil and transistor no spark. Resolution. [Re: off-roader] #425032 03/30/04 11:34 PM
merikgvr4&sr Offline
Hey Mendel, did you receive the power block and did it work for your Monty?
e
89 Malljero 4dr V6
94 Monstero SR (sold)
91 GVR4 turbo powa too many mods
83 300TD turbo diesel powa
Re: No spark, replace computer, no spark, replace coil and transistor no spark. Resolution. [Re: merikgvr4&sr] #425033 03/31/04 12:48 AM
Mendel Offline OP
It just came in the mail today. I'll try it out once we get a replacement ECU. Thanks.
BTW, I'm working on getting another, so if you need one again, just PM me.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6432 MB (Peak: 0.7688 MB) Data Comp: Off Server Time: 2026-06-17 04:21:44 UTC
