no spark... ignition coil test?
#425054
03/27/04 11:58 PM
My '86 4Runner with 430K on the original 22re will not start. I don't believe there is any spark at the plugs(I pulled a couple of the plugs and cranked the engine just to make sure). That leaves the ignition coil, however, I don't know of any easy way to test it. Anyone have any suggestions? I did a forum search for ignition coil test and couldn't come up with anything.
My '86 4Runner went to the bone-yard November 29, 2004 at 10am after roughly 430,000 miles on the original engine and transmission. :-( Looking for something else to wheel in...
Re: no spark... ignition coil test?
[Re: ecowheeler]
#425055
03/28/04 12:04 AM
Check for spark at the coil, the same way you check your plug wires, also check your ignitor! Also, open up the dist. and make sure that the rotor is spinning! "Maybe time has come!"
#425056
03/28/04 12:46 AM
pit your hand on the spark plug end... hehe It works but it hurts <img src="/forums/images/graemlins/cheers.gif" alt="" />
2006 tacoma SR5 4x4 V6 Auto
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5898 MB (Peak: 0.6434 MB) Data Comp: Off Server Time: 2026-06-07 09:09:11 UTCValid HTML 5 and Valid CSS
