Got my Aisins, quick ?? #426238 03/29/04 10:57 PM
Brian_M Offline OP
Just wanted to see if anyone has found a good source for the o-ring and 2 gaskets outside of the Toyota dealer. I dug up this info here:
so the official part numbers are (thanks scott!)
Locking Hub O-ring (this is the o-ring for the part that you turn to lock the hubs)
43532-60010
Locking Hub Star Gasket (this is the gasket that separates the halves)
43531-60010
auto hub gasket (this the gasket that mounts the aisin hub to the rotor area)
43422-60010
but I've got a natural hate of Stealers.. er, I mean Dealers because I've been broke my whole life and they always want an arm and a leg for everything. So I'm just checking to see if anyone has a good source. LOL, guy I bought em from said 'they're clean, no need to rebuild'... arrive covered in black grease, o-rings in a couple pieces, no gaskets.... ohwell, they're all clean now.
Thanks in advance.
Cheers,
Brian M
'97 T100 SR5 4x4, with Buckets
Re: Got my Aisins, quick ?? [Re: Brian_M] #426239 03/29/04 11:10 PM
Chris V Offline
I just rebuilt mine. It cost $15 for all the gaskets and o-rings you listed, not bad for dealer parts.
Rebuild them right and you can get some bling like I have:
1996 T100 SR5, 4" Procomp Stage2,
33x12.5x15 tires
http://members.cardomain.com/chris_t100
Re: Got my Aisins, quick ?? [Re: Brian_M] #426240 03/29/04 11:27 PM
adam Offline
Is the hub/rotor gasket the large paper star-shaped one? They suggested at the parts counter here just using rtv for that one - keeps water out better.
~Adam
Re: Got my Aisins, quick ?? [Re: adam] #426241 03/30/04 12:30 AM
surlynkid Offline
no, the star shaped one separated the two half of the aisin.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Got my Aisins, quick ?? [Re: surlynkid] #426242 03/30/04 01:00 AM
adam Offline
oh. <img src="/forums/images/graemlins/sleeping.gif" alt="" /> duh. 's right; the plain circle is the innermost.
Well, why not use rtv for both.
~Adam
Re: Got my Aisins, quick ?? [Re: adam] #426243 03/30/04 04:21 AM
Honger Offline
<img src="/forums/images/graemlins/confused.gif" alt="" />
rtv?
Enlighten me as I am going to be rebuilding a set soon.
1998 Toyota T100 SR5 ExtraCab 4WD
Re: Got my Aisins, quick ?? [Re: Honger] #426244 03/30/04 04:30 AM
little_joe Offline
Former Admin
I use Permatex Hylomar on mine instead of the paper gaskets. This is a non-curing compound, and can be disassembled and reassembled w/o cleaning it off. It does a superior job of sealing out water and debris, and seals just as well after disassembly.
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Got my Aisins, quick ?? [Re: little_joe] #426245 03/30/04 05:14 PM
adam Offline
What little joe said or the 'hardening' style blue or black silicone. I like using a clean seal and might think <img src="/forums/images/graemlins/barf.gif" alt="" /> would accumulate on the outside edge of a non-curing compound enough to justify being wiped down and fortified on a rebuild, but if he says it seals I'd be inclined to believe it.
~Adam
Re: Got my Aisins, quick ?? [Re: adam] #426246 03/31/04 03:09 AM
ErikB Offline
Toyota Moderator
I wouldn't use silicone or anything that could act slippery between the locking hub and wheel hub. You want the bolts to clamp down and create FRICTION to drive the wheel...
http://home.4x4wire.com/erik
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6285 MB (Peak: 0.7331 MB) Data Comp: Off Server Time: 2026-07-09 19:31:16 UTC
