SES light +Tranny problems + weird speedo problem = related issue ? #426400 03/30/04 03:20 AM
P
pu12en12g Offline OP
My 1992 Isuzu Rodeo XS has been driving GREAT since I got it, with the exception of what seemed to be a front wheel bearing (pulling to the rigth even at high speeds), but turned out to be a mystery. Also I know I need new shocks.
Got a high milage oil change.. symptoms 2 and 3 started since that oil change
1st symptom: occasional SES light
2nd symptom: tranny seems to have a mind of its own, seemingly losing power / slipping even when simply cruising at speed (VERY WEIRD FEELING). Sometimes doesn't happen at all, and sometimes happens for a few minute interval and then seems to be ok ? ? So Not heat related ? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
IT COULD BE MY IMAGINATION, BUT it seems like this symptom kicks in on turns, or after bumps in the road. In fact, the first day that it happened, I had slammed on the brakes and skidded about 20-30 ft (oops).
3rd symptom: Speedo occasionally stick at 25mph mark
What I have done:
- Seafoam the fuel system
- Oil change
- Tranny additive (thick expensive bottle)
What should I do next ? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
1999 Isuzu Amigo 4WD
Re: SES light +Tranny problems + weird speedo problem = related issue ? [Re: pu12en12g] #426401 03/30/04 05:00 AM
O
OffRodEO Offline
get the alternator checked. Seems more like an electrical problem.
kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
Re: SES light +Tranny problems + weird speedo problem = related issue ? [Re: OffRodEO] #426402 04/02/04 09:13 PM
P
I'm getting the tranny filter replaced, and checking the intake manifold o-ring ground wire. Hopefully I don't get raped at this repair shop <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: SES light +Tranny problems + weird speedo problem = related issue ? [Re: pu12en12g] #426403 04/02/04 10:05 PM
Bigpoppax2 Offline
I'd go to autozone and get the codes pulled. Then post back.
The falling on it's face and half stalling is probably not the tranny, it could be your map sensor. I had a car act like that before and it was the MAP.
Just a thought, maybe you could test it or have it tested.
Re: SES light +Tranny problems + weird speedo problem = related issue ? [Re: Bigpoppax2] #426404 04/14/04 03:10 AM
P
Well I went to autozone... they didn't have the right equipment to pull the code <img src="/forums/images/graemlins/frown.gif" alt="" />
Anyways, I think I pinponited the problem... this is only happening in what feels like overdrive (4th ? ) gear. Does that = tranny rebuild time for sure ?
WOO HOO [Re: pu12en12g] #426405 06/01/04 05:48 PM
P
Woo Hoo... it was a bad coilwire and bad plugwire # 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6089 MB (Peak: 0.6795 MB) Data Comp: Off Server Time: 2026-06-09 23:36:29 UTC
