SES light +Tranny problems + weird speedo problem = related issue ?
#426400
03/30/04 03:20 AM
My 1992 Isuzu Rodeo XS has been driving GREAT since I got it, with the exception of what seemed to be a front wheel bearing (pulling to the rigth even at high speeds), but turned out to be a mystery. Also I know I need new shocks.
Got a high milage oil change.. symptoms 2 and 3 started since that oil change
1st symptom: occasional SES light
2nd symptom: tranny seems to have a mind of its own, seemingly losing power / slipping even when simply cruising at speed (VERY WEIRD FEELING). Sometimes doesn't happen at all, and sometimes happens for a few minute interval and then seems to be ok ? ? So Not heat related ? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
IT COULD BE MY IMAGINATION, BUT it seems like this symptom kicks in on turns, or after bumps in the road. In fact, the first day that it happened, I had slammed on the brakes and skidded about 20-30 ft (oops).
3rd symptom: Speedo occasionally stick at 25mph mark
What I have done:
- Seafoam the fuel system - Oil change - Tranny additive (thick expensive bottle)
What should I do next ? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
1999 Isuzu Amigo 4WD
Re: SES light +Tranny problems + weird speedo problem = related issue ?
[Re: pu12en12g]
#426401
03/30/04 05:00 AM
get the alternator checked. Seems more like an electrical problem.
kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
[Re: OffRodEO]
#426402
04/02/04 09:13 PM
I'm getting the tranny filter replaced, and checking the intake manifold o-ring ground wire. Hopefully I don't get raped at this repair shop <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: pu12en12g]
#426403
04/02/04 10:05 PM
I'd go to autozone and get the codes pulled. Then post back.
The falling on it's face and half stalling is probably not the tranny, it could be your map sensor. I had a car act like that before and it was the MAP.
Just a thought, maybe you could test it or have it tested.
[Re: Bigpoppax2]
#426404
04/14/04 03:10 AM
Well I went to autozone... they didn't have the right equipment to pull the code <img src="/forums/images/graemlins/frown.gif" alt="" />
Anyways, I think I pinponited the problem... this is only happening in what feels like overdrive (4th ? ) gear. Does that = tranny rebuild time for sure ?
WOO HOO
[Re: pu12en12g]
#426405
06/01/04 05:48 PM
Woo Hoo... it was a bad coilwire and bad plugwire # 3
